Olds 330 heat riser problem
Old Jun 27, 2012 | 02:40 PM
at3reg98's Avatar
New 2 Olds
I have an exhaust leak from around the heat riser valve shaft. The spring is long gone and I guess there would be a bushing in the hole but it's missing. Does anyone know of a replacement, or even how to remove it from the manifold? Never saw a setup like this before.
Old Jun 27, 2012 | 04:24 PM
Run to Rund's Avatar
I don't thiink they are repairable at all easily. I have a pair from a 67 Cutlass 330 that I could check, but they are probably good since the car has been sitting since the mid 80s.
Old Jun 27, 2012 | 04:38 PM
You can buy them new/used, or you can go to a muffler shop and have them weld it.
Old Jun 27, 2012 | 04:39 PM
at3reg98's Avatar
New 2 Olds
I'm wondering how you'd get it off the manifold.. I'd probably just have to buy the manifold complete. Be sure to let me know what you find..
Old Jun 27, 2012 | 05:16 PM
TripDeuces's Avatar
Mine had no bushing. I ended up cutting it out and tapping the hole for a pipe plug. My spring was gone also
Old Jun 27, 2012 | 05:21 PM
64Rocket's Avatar
Once you take the head pipe off, the heat riser slides off.
I would have the muffler shop cut the shaft and weld up the holes.
Gene
Old Jun 27, 2012 | 05:45 PM
at3reg98's Avatar
New 2 Olds
I might as well get rid of it then, it's just rattling around and leaking. Supposedly they don't do a whole lot anyway.
Old Jun 27, 2012 | 06:28 PM
"Once you take the head pipe off, the heat riser slides off."
This is a 330 not a 394!
Old Jun 27, 2012 | 09:27 PM
64Rocket's Avatar
You know your right. It has been a while since I had to do one of those.
I say cut the end of the shaft, slide it out and weld up the holes.
Gene
dingusboy
Mar 8, 2014 07:09 AM
1977 Delta 88 Flint
Dec 24, 2012 11:25 PM
Ian U
Jul 7, 2010 01:39 PM
StickW31
Jan 21, 2010 08:12 AM
bjtstarfire
Nov 13, 2008 02:04 PM
