ok? quick question about a spudder
I currently have a 455 with an offenhauser intake, edelbrock 750 carb, msd, with a high volume mechanical fuel pump.(also the carb was rebuild about 9 months ago) It has a slight spudder when you stomp on the gas from and idle. I cant seem to figure it out, not sure if its not gettin enough fuel or whats goin on. Any food for thought would be great thanks.
Also one other thing got a belt squealing at a high rpm any ways to fix this? (tryed replacing the belt, tryed using belt conditioner, and tryed using soap and WD 40) Nothing is workin :| ......trying to avoid buying another pully.
quick question about a studder
Yea I made sure the belts are tight. No its an A body style,It did have stock AC but disconected it, I do still run two belts tho. One goin around the power steering to the altenator, second goin around the crank, power steering, and water pump this is the one that normaly squeals.
Thanks for the suggestions on the carb ill check them out
Have you tried adjusting the accelerator pump?
http://www.edelbrock.com/automotive_...ech_vids.shtml
About the pulley. Never use any "stuff" on a belt it will not fix a slipping belt. I am sure you have now polished said pulley's to a high gloss smooth finish. Rough up the pulley's groove with a round file.
There are THREE fasteners that you need to loosen to adjust the belt, the two bolts on the front and the one nut at the bottom rear of the pump. Once you loosen all three, use a large screwdriver as a pry bar and insert it between the nose of the pump and the tab on the bracket, between the pulley and the bracket. The photo shows the proper position of the screwdriver with the pulley removed for clarity. Use the screwdriver to tension the belt while tightening the two bolts on the front, then get the nut on the back. Failure to do this properly is why there are frequent posts about belts squealing.
By the way, belt squealing is due to slippage, so adding lubricant like soap or WD-40 is NEVER a good idea. It probably means that you need a new belt now, in addition to being sure all the lubricant is off the pulleys.
