Oil Pressure
Oil Pressure
I just finished adding a Mechanical oil pressure Gauge.Instead of using the plastic oil line I chose to use the stainless steel hose.WOW it was over half the price of the gauge itself. But I feel better with less of a chance of a leak.Then I started the car the gauge went to about 62-63 pounds of pressure. I reved it up it about 1800 RPM and it jumped to over 80.I then cut it off.Are those number normal.I had the motor rebuilt and have about 700 miles on it. I used a breakin oil for the first 500 miles and changed out to a non synthetic oil for the next 1000 miles then at that time am going with synthetic.
I advise against that, the air in the line acts as a damper, stopping shock loads on the gauge. The gauge will read true with air in it, it's not like a brake line.
Roger.
40psi with a hot engine above idle speed and 20psi idling is fine for street use. Maybe a bit more if you are caning the car down a strip or racetrack but there is no realistic need for more than 60psi IMO.
Don't forget the oil pump uses power from the engine, the more pressure the greater the load, which is imposed on everything that drives the pump, distributor gear, drive shaft, timing chain etc. It's not a huge amount I know, but don't overkill it.
Roger.
Roger.
Roger.
Roger.
railguy
72Blazerod
Jan 1, 2015 10:04 AM
