Ebay radiator
Old Jun 9, 2014 | 08:04 PM
s i 442's Avatar
Oldsmobile enthusiast
Ebay radiator
This is the radiator I have used for years without any problems.
No, they aren't OEM or factory, they look good and work good.
If someone pays over $500 for another brand they just have money to burn.
I just ordered another one today!
http://www.ebay.com/itm/201075095875...84.m1497.l2649
Old Jun 9, 2014 | 10:45 PM
Alex72cutty's Avatar
Are you running electric fans?
Old Jun 9, 2014 | 11:30 PM
oldstata's Avatar
Justin
Thank you, I have been looking at there 65/66 one and have been pondering if I should risk it,
Old Jun 10, 2014 | 12:44 AM
s i 442's Avatar
Im not running electric fans this time but as good as these cool you can run what you want. Im going to run a simple 6 blade after market flex fan.
Old Jun 10, 2014 | 11:32 AM
Tom442's Avatar
Which brackets do you have?
Was your car(s) a four core radiator? Did you have to swap the saddles on the core support and top plate for the aluminum radiator to fit right?
Tom
68 442
70 F85
Old Jun 10, 2014 | 05:41 PM
Mr Nick's Avatar
I'm using one from Northern Products from ebay, cheap and works great. I'm also using their alum shroud with dual Spal fans. Killer set up.
I agree, some of the big name radiators seem overpriced.
Interesting that it shows it fits both the '68-'70 and the '71-up Olds engines, yet the radiator hose and radiator outlet are different sizes between the '68-'70 and the '71-up Olds engines.
So what size is the outlet hose nipple? 1.75" for the early engines or 1.5" for the later engines?
Old Jun 11, 2014 | 02:02 AM
Do you have a link to both the radiator and the fans?
Old Jun 11, 2014 | 05:31 AM
s i 442's Avatar
Tom
68 442
70 F85
My car was a 3 core from the factory and the top plate fits fine.
Old Jun 11, 2014 | 06:45 AM
Mr Nick's Avatar
Radiator only:
http://www.ebay.com/itm/68-77-CHEVEL...item460f92ef3f
Radiator, shroud, and dual fans for $509:
http://www.ebay.com/itm/68-77-CHEVY-...item43bba1226d
Go to their store for other options. Make sure you get one with auto trans cooler, if needed.
Old Jun 11, 2014 | 08:05 AM
Thanks Mr. Nick.
Old Jun 11, 2014 | 09:45 AM
70cutty's Avatar
Beer Connoisseur
Alex I got the same radiator that Mr.Nick has, make sure you order the wiring harness from them, they will cut the cost of shipping.
Old Jun 11, 2014 | 09:51 AM
Good to know. Did you purchase your off ebay too?
Old Jun 11, 2014 | 10:14 AM
66ninetyeightls's Avatar
Land Yacht Captain
Boo nothing for older land yachts!
Old Jun 15, 2014 | 06:47 PM
s i 442's Avatar
Here is the pic of the radiator I ordered,
Its not for the original crowd but more for people who like to upgrade and modify their hotrod.
The top hole is 1.5 inches, the bottom is, 1.58 inches.
Its 33 1/4 wide and 18.5 tall.
Its fits the radiator support and the top plate fits.
Old Jun 15, 2014 | 07:28 PM
Mr Nick's Avatar
That polished finish is nice!
I like how you can see the aluminum radiator behind by black grills.
Old Jun 22, 2014 | 11:36 AM
Stevec's Avatar
I bought one of those! Didn't even get to start the engine it leaked all over the garage floor!
I'm in the process of getting a refund and I will then buy a becool radiator.
Old Jun 22, 2014 | 12:15 PM
Mr Nick's Avatar
Steve - what was the problem? I'm bummed I suggested it to you, and it caused a headache.
Old Jun 22, 2014 | 01:11 PM
Stevec's Avatar
Nick I was very impressed when I got it,it looked great! Two huge 13" Spal fans I was really impressed.
Then I filled it up with antifreeze got half a gallon in and it was pouring out of the left lower corner. A leak like this,I doubt this radiator was ever tested! Anyways took it out because it's still under warranty and I'm waiting to hear back from them. I'd like a refund but gotta wait and see what they say.
I kind of lost all faith in them as far as their product goes,it was supposed to cool my new BTR built engine but I just can't risk it!
No worries Nick not your fault,back to the drawing board I guess..
Old Jun 22, 2014 | 01:14 PM
oldstata's Avatar
Justin
Was it the Northern or the champion ?
I know a few members that have been running the Northern and have said they were great
Old Jun 22, 2014 | 01:39 PM
So how did you adapt the lower hose to the smaller diameter radiator fitting?
Old Jun 22, 2014 | 02:02 PM
Stevec's Avatar
It was from universal parts inc. I got the lower radiator hose on by using a silicone band that came with a universal radiator hose. Slipped it over the radiator fitting and the hose over that.
Old Jun 22, 2014 | 03:10 PM
s i 442's Avatar
So was it a Champion?
Old Jun 22, 2014 | 03:52 PM
Stevec's Avatar
No from universal parts inc....
Old Jun 22, 2014 | 04:48 PM
I got my Champion Radiator in the mail on Friday. I'm very please with it. Lifetime warranty too. I'm thinking about getting one for the other project too.
Old Sep 6, 2014 | 09:46 AM
snowman's Avatar
Reviving a 68 Cut conv
Looking into a new radiator.... Now that summer is almost over, I wonder what you guys think about your units? It looks like they fit in well, how did they hold up in the heat?
Old Sep 7, 2014 | 08:18 AM
Mr Nick's Avatar
Mine is still fine. Put about 2,000 miles on the car this summer, 600 or so where on the Power Tour. Zero cooling issues with for me. 425hp 350 with dual electric fans.
170 T-stat, runs 175ish on the highway and cycles between 190-175 at idle as the fan turns on and off.
Alex72cutty
Apr 21, 2015 10:30 AM
59Olds98
Aug 14, 2013 09:38 AM
g77rvd
May 13, 2011 11:29 AM
Oldsmaniac
Jan 16, 2006 05:55 AM
