Oil pan nut?
Old Jun 10, 2012 | 03:44 PM
m1fresh's Avatar
Oil pan nut?
Hello I was planning on changing the oil in my 1965 cutlass 330, does anyone no the size of the star bolton the oil pan? Got a T 70 from the auto store but it seems to big...
Old Jun 10, 2012 | 04:44 PM
According to the info on RockAuto it should be DORMAN Part # 090052. Cheap - 1.00
EDIT: Forgot to add this Head Size: 9/16"; Head Style: Hex 1/2-20 Thd Fits 1961 - 1994
Old Jun 10, 2012 | 05:02 PM
Lady72nRob71's Avatar
star bolt? Sounds aftermarket to me. Shoulda been a plain hex bolt from the factory.
Old Jun 10, 2012 | 05:04 PM
The other thing that sounded wrong was T70 - That's a torx screw/bolt
Old Jun 10, 2012 | 05:24 PM
m1fresh's Avatar
That's what I thought till I got under there, I believe it is a torx bolt. Thanks
Old Jun 10, 2012 | 05:27 PM
m371961's Avatar
My 65 425 has a bolt that looks something like a torx, but has 8 "points". I just use a 1/2 inch drive extension and it works fine. I believe I have seen a wrench in the past made for these, even have one somewhere? Just be gently, don't let it slip and don't overtighten. Someone here should know if a wrench was made for these. To my knowledge no american auto used any torx hardware in 65.Maybe replace it with a hex head if you get the right one.
Old Jun 10, 2012 | 05:37 PM
The picture that Allan posted is exactly what it should look like.
If it looks like anything else, then someone has messed with it.
Old Jun 10, 2012 | 05:40 PM
2blu442's Avatar
1965 330 was unique. I'm not sure if the big blocks used it but the 330 in the Cutlass used a flush mounted plug that can be removed with a 1/2" ratchet. This picture isn't real good, I'll try to get another one to post. John
Old Jun 10, 2012 | 05:43 PM
Funky! Kinda like a square rear diff plug - try to use a ratchet extension....
Old Jun 10, 2012 | 05:44 PM
Well I'll be...
So it's like a differential drain plug then.
Thanks, John.
Old Jun 10, 2012 | 05:46 PM
2blu442's Avatar
Here's some better pic's. My guess is that the bottom of the oil pan is pretty close to the same level of the crossmember. So the conventional plug would have the head scraped off if you drug over a speed bump. The problem with that theory is if so why didn't they use it for other years! One of the 1965 guru's will have to explain it better
Old Jun 10, 2012 | 05:52 PM
m1fresh's Avatar
That's it! Now to get that SOB off? So just try w/ ratchet?
Old Jun 10, 2012 | 05:55 PM
2blu442's Avatar
Yes. Just like m371961 suggested you can put the square part of a 1/2" ratchet in there and remove it. Hopefully it's been removed in the last decade and not cemented in there with gunk!
Keep us posted on how you do! John
Old Jun 10, 2012 | 06:17 PM
m1fresh's Avatar
Got it off! Thanks Gentlemen!
Old Jun 10, 2012 | 06:24 PM
Originally Posted by MDchanic
Well I'll be...So it's like a differential drain plug then. Thanks, John.
X2 You learn something new here everyday.
Old Jun 10, 2012 | 06:30 PM
2blu442's Avatar
That goes to show we're never too old to, to, um... where was I going with this? There's something else that happens when we get old too
Old Jun 10, 2012 | 06:45 PM
I know zackly what you mean, but for the life of me I can't remember what it is either... and I qualify because I'm waaaayy older than you
Old Jun 10, 2012 | 07:01 PM
Octania's Avatar
There was indeed a special tool made to service this oddball 8-pt or double square drain plug. As you see, though, a 1/2 drive ratchet/ breaker/ extension/ etc. serves ok.
Old Jun 10, 2012 | 07:58 PM
Sugar Bear's Avatar
Looks exactly like the original plug that was in our 65 Vista Cruiser 330 4bbl. As previous posters said a 1/2" drive ratchet or breaker bar without any socket or bit should work well. About the design, I agree it is less likely to get torn out by an object in the road or the road itself if bottoming out.
Old Jun 11, 2012 | 05:23 AM
D. Yaros's Avatar
The plug in the picture was also used, at least in 62 & 63. Yes, a special wrench/socket was in fact made for it. Yes, a bare 1/2" drive does work on it.
Old Jun 11, 2012 | 05:39 AM
m371961's Avatar
Was going to get a pic of mine today, but you guys got it here first. Too lazy last night to get out of recliner.I know I had a wrench like that around long before I had anything to use it on, didn't have a clue what it was for and misplaced it somewhere.Must of done it because the pan is so low. All the dents in mine show it's been dragged before.
Old Jun 11, 2012 | 07:08 AM
Run to Rund's Avatar
Glad this one got sorted out quickly. Yes, the unusual plug was OEM, yes it is removable by a 1/2" drive ratchet, and yes, Torx wasn't invented back then. Torx would be usually 6 point, but Bosch used 5 point sometimes. According to Wikipedia:
Torx (pronounced "torks") developed in 1967[1] by Camcar Textron,[2] is the trademark for a type of screw head characterized by a 6-point star-shaped pattern
Old Jun 11, 2012 | 10:14 AM
Well then, a torx wouldn't work at all on that plug seeing as it has 8 sides.
Old Jun 11, 2012 | 12:02 PM
rocketraider's Avatar
Oldsdruid
All 61-65 Olds V8 except the 215 used this drain plug, so it's not exactly unusual. Yes, there was a special 8-point bit made to remove it (which should be in any hardcore Oldspunk's tool box), but as some of you have found a 1/2" drive ratchet will remove it. I've never had any luck using an extension as those tend to spin in the recess and round out the flutes in the plug. Use the ratchet by itself.
Last edited by rocketraider; Jun 12, 2012 at 08:00 AM. Reason: correct years of use
Old Jun 11, 2012 | 08:50 PM
Octania's Avatar
"Oldspunk" - good one. Like "steampunk"?
In my experience, that recess drive plug was found only on 1965 425's and now perhaps 330's- not thru 1967.
Anywho I happen to have one of those tools, so I can share what it looks like:
Old Jun 12, 2012 | 05:31 AM
D. Yaros's Avatar
That is the same tool I have for my car, which is a 1962. I also know from personal experience that the 1963 also had this drain plug.
Old Jun 12, 2012 | 06:12 AM
2blu442's Avatar
Wow I had no idea! Over the years I've owned a couple dozen 1964-67 engines and this is the only engine that still had the plug. Somewhere along the way I'd been told this was a 1965 only and I just ran with that mis-information. Thank you for the clarifications everybody, this will be a good reference thread for future questions about this plug. John
Old Jun 12, 2012 | 07:57 AM
Oldsdruid
Yup. I like "Rocketpunk" better but seems the sci-fi crowd co-opted that first as a reaction to steampunk.
I stand corrected. Parts book indicates it was last used in 65.
Old Jun 12, 2012 | 08:02 AM
logsplus's Avatar
I sell the "Bonney" socket you need for the oil pan. I have them on ebay. I am oldsrus on ebay. It ad is Bonney socket 62 Olds. My email is oldsrus@comcast.net
Paul
Old Jun 12, 2012 | 08:04 AM
logsplus's Avatar
Paul
Old Jun 12, 2012 | 12:22 PM
  #31
Oldsdruid
Thumbs up
Originally Posted by coldwar
Genuine Oldsmobile approved tool to make others aware you are serious about correct service methods on your Oldsmobile, a quality product of the General Motors Corporation. CW
Now that is the way a true Oldspunk should think!
I have a pile of Burroughs and Kent-Moore dealer tools, and I figure that when I have Rocketed out of this world and my estate is being sold off to the highest bidder, someone is going to pull their hair out trying to figure out what these tools do. Hey, I have the catalogs too...
Old Jun 12, 2012 | 01:10 PM
  #32
m1fresh's Avatar
Just bought them! Thanks Oldsrus
Old Jun 13, 2012 | 09:43 PM
  #33
BILL DEMMER's Avatar
Just the facts...
all of the '65 425's i've collected had that drain plug(and a healthy-sized drain hole too!)
when you remove that plug, the pan drains NOW.
bill
Old Oct 29, 2014 | 01:30 PM
  #34
CharlieZ's Avatar
Found this post after crawling under the car to change the oil for the first time since I Bought the car. The half inch drive worked perfectly! Definately a strange oil pan nut!
Redog
Oct 20, 2015 03:29 PM
bob p
Jun 4, 2015 01:53 PM
AzChevs
Oct 8, 2014 10:13 AM
defiant1
Aug 12, 2014 04:43 PM
