Odd throttle problem
Old Oct 25, 2017 | 07:42 PM
devmar07's Avatar
I have a 72 cutlass and I was driving the back roads tonight getting on it here and there and I went to brake at the stop sign and it was running 1700 rpm without touching the pedal. When I got home I popped the hood and the linkage was fine I'm not sure what' going on
Old Oct 26, 2017 | 02:36 AM
Did the choke engage?
Old Oct 26, 2017 | 03:52 AM
toymobile's Avatar
Sounds lit the QJ secondary stuck partly open.
easy fix, snap the secondary linkage open, then oil both sides of the secondary throttle shaft and work the oil in with the ENGINE OFF.
Good luck hope this helps.
Johnny
Old Oct 26, 2017 | 06:09 AM
devmar07's Avatar
I will give it a shot thanks for the help
Old Oct 26, 2017 | 06:39 AM
Johnny
I would not recommend lubricating any throttle linkage or bushings. The oil simply attracts underhood grit.
Look for binding in the throttle cable. As the individual wires in the cable start to fray, they dig into the teflon liner in the sheath.
Look for sticky residue on the linkage.
Look for a choke coil gone bad or a swelled throttle body gasket that may be causing the secondaries to hang up.
Look for worn throttle shaft bushings that can either admit additional air or can let the throttle plates get off center, allowing them to hang up.
Old Oct 26, 2017 | 11:47 AM
Also make sure the throttle return spring isn't stretched out.
Old Oct 26, 2017 | 11:58 AM
devmar07's Avatar
Here' a little more info it's a Holley with a manual choke and I did check all of the linkage and springs which most of the parts are somewhat new. I think the secondaries are to blame from not driving it much and I never drive it hard so i will clean everything and see how it responds
Old Oct 26, 2017 | 01:13 PM
Make sure the manual choke arm is all the way forward and the choke flap is all the way open. Check your vacuum lines.
defiant1
Feb 4, 2020 08:53 PM
sqeeek
Mar 14, 2017 10:35 AM
chrisneu68olds
Nov 29, 2014 07:06 PM
olds70supreme
May 7, 2013 09:28 AM
MeanGrnGt
Brakes/Hydraulic Systems
Jul 20, 2008 05:34 PM
