OBDI code retrieval Problem 93 OLDS Cutlass Cierra
The car started stumbling, then became hard to start, then would crank, but not start. I used the paper clip trick in A and B to obtain the Codes. When I turned the key on, the Engine Cooling fan started to run, and stayed running and all I got from the codes was the 12's with no other codes. It continued flashing the 12's and fan ran until I turned off key.
Any Ideas would sure help.
Thank you
Thank you
Pull a plug wire- check for spark. No Spark=replace Ignition Control module. a bad ICM will not set a code.
Thank you
Thank you
Unless the Check Engine light was on, there are no stored codes to read. Keep in mind that there are MANY possible failures that do not set a code. The codes are only set if a part fails that is tied to the computer. The OBDI computers are very limited in capability due to limited processing power.
Get a factory Chassis Service Manual and follow the troubleshooting steps in it.
Thank you, L
No Check Engine Light/Service Light.
Engine turns over and fires, tries to start, then just cranks.
I hear the fuel pump engage when I turn on the key. Held gas pedal to floor on another occasion same thing.
thank you, L
1CUTLASS
May 12th, 2015 06:52 AM
