OAI. Air cleaner bucket
Hello all, can anyone tell me if the air cleaner bucket on a 455 supreme is the same as the 442 OAI. Hood? I'm converting to the ram air hood and now looking for a bucket.
Thank you,
Mike
Thank you,
Mike
The round part of the 4 bbl air cleaner will work weather it is a factory OAI or just a regular 4 bbl but the snorkle is wider at what you call the bucket on an OAI car than a regular 4bbl air cleaner. See Adams picture above.
I understand. Thank you! How does the vacuum work on the top part. I imagine when vacuum drops the door opens. Is that just for air going g into the secondarys on the carb or does it need all 4 barrels?
Yes, when the outside air flapper is closed, the air comes down the snorkel. That air is a mixture of under-hood air and heated air from around the exhaust manifold. The vacuum-operated flapper at the end of the snorkel controls air temperature by balancing the amount of air from each source.
