no fire @ spark plugs
Old Aug 5, 2013 | 11:09 AM
Matt Hohmann's Avatar
1986 Olds calis 2.5 liter 4 cyl engine. I have checked the ecm fuse-allok , I have cranking yet no fire @ spark plugs, new cap & rotor! Can anyone supply a diagram on the coil positive wire location? there are 2 plastic plugins on the coil. Which one supplys 12v to the coil or even distributor. I had a few years back replaced the ign, module . Also how to check the ign module itself? Thax.
Old Aug 5, 2013 | 11:46 AM
rjohnson442's Avatar
Mr. Johnson
NS switch maybe. Ignition module you can't test they either work or replace with a know working one. Use a voltmeter to determin which wire is the batt positive or the coil has a + on it usually.
Old Aug 5, 2013 | 12:39 PM
Professur's Avatar
There's a couple of thin wires from the module ... separate them. If the insulation is dried out, they could be cross talking. Happened to me once. One of the few times my cars ever left me stranded.
bob p
Apr 10, 2015 01:55 PM
RustRocket
Sep 5, 2014 10:14 PM
navvet
Mar 24, 2014 03:13 PM
Wyze
Mar 27, 2010 04:25 PM
The_Jeremiah
Jan 26, 2008 01:56 AM
