Nice find! "Soft trim broadcast" paper!
Old Mar 28, 2015 | 02:17 AM
Christophe2m6's Avatar
Hi guys!
Still restoring my 69 Cutlass Supreme!
You can see some pics and follow the work here: https://classicoldsmobile.com/forums...day-coupe.html
Got my seat reupholstered, and found the Soft Trim Broadcast behind the rear seats!!
What are all these options codes on the Soft Trim Broadcast?
Also found another paper under the carpet while removing it!
Old Mar 30, 2015 | 01:50 AM
Never seen anything like that before -- what plant is it from?
Old Mar 30, 2015 | 02:55 AM
1970cs's Avatar
Lansing built
I had the same question too! But Compton kinda gives it away and then hit his link back and it's Freemont.
Pat
Old Mar 30, 2015 | 05:13 AM
Whoops. Missed that.
Old Mar 30, 2015 | 05:30 AM
sammy's Avatar
Sammy70 455 Supreme
Found the same in my 70 Supreme from Freemont. The first section corresponds to the build sheet...s***t, gotta go to an appointment...finish later
Old Apr 1, 2015 | 01:10 PM
Yes, indeed! It's Fremont!
Model (34287) /Trim (974) and Serial No (1655) are exactely what is mention in the VIN and on the data plate!
But still looking for all these codes appearing in cases: 77 / 78 / 79 / 83... /86
And what are the A/C/D/U Options...?
Old Apr 1, 2015 | 04:10 PM
sammy's Avatar
Sammy70 455 Supreme
They are interior codes that respond to the build sheet.
Eg box 77 on the build sheet is the front carpet.etc...the actual code I am not sure of...carpet Color etc
They were used for the assembly of the interior of the car and the options it was ordered with
A codes...A51 strato bucket seats
A31 power windows
Y60 accessory light group
D55 console
Codes are available in CSM, build sheets etc
1k442
Sep 30, 2010 08:37 AM
1k442
May 20, 2010 11:55 AM
1k442
Apr 18, 2008 11:16 AM
