New gears for my 70 olds cutlass W-31
Hi fellow Olds guys! I have a 1970 W-31 with a 12 bolt rear end. It has that style rear end that will only fit the 3:91 which I currently have. Or a 3:42 ratio. I am wondering where I can find the 3:42's at? Any info and advice would be greatly appreciated. I am obviously trying to shave some RPM's off with out the expense of a OD trans.
I would contact Monzaz or 507Olds on here. You need original gears since the aftermarket gears are set up for the 3.08-3.23 carriers. Either that or a spacer would be needed or is it the Richmond gears need shaved? I still say they should have been designed to fit the 2.56-2.78 carrier since most cars have those ratios.
As stated above, you would need to find an original set of GM gears since no one makes 3.42s for the O-Type.
Actually, Richmond does but for some reason the 3.08-3.23 carrier was chosen.
But...
You made no mention of the 671 carrier. It will however work.
Didn't think I needed to say much more than I wanted 3.42s instead of 2.56s in my '70 O-Type. How I get there from here wasn't the issue.
I have parts to work with:
Why?
I did not want novice olds owners to think that the Richmond 3.42 gear could be used in the 2.56 differential. A first time reader may have thought so from your original post.
monzaz
January 4th, 2017 07:35 PM
86GutlessCutlass
May 13th, 2016 09:14 AM
monzaz
Drivetrain/Differentials
August 7th, 2014 11:12 AM
