New Cutlass owner Needs some help
#41
Why do you say that? It's nearly identical to documented tags from 1966 Chevelles produced at the same plant and has the same format as documented Oshawa cowl tags used from at least 1964-67 (and likely earlier), as found on A-bodies, Novas, and Impalas built at that plant. It has all the correct info for a 1966 Cutlass convertible. It was an education for me, but I think the evidence is pretty conclusive.
Also note the relatively low production number on this one too as a comparison to the June build for the OPs car. Everything seems to match up so with all the evidence pointing to the VIN and trim tags being valid, I accept they are. This will also make it much easier for the OP to get documentation (as mentioned earlier) from Vintage Vehicle Services ; representing GM of Canada Limited.
