New Arrival 72 442 Not Mine
Since I eat sleep and breath Oldsmobiles I thought I would post some picts of my brother's new ride. He has been searching for about a year for a stick 70-72 442 with 71 his favorite year. Wow seems the prices are really up there for these cars! He finally pulled the trigger on this 72 3 speed stick floor shift. It is said to have 58,000 original miles and has been repainted in the original color. W25 and rear wing are factory items but were added. The original check list dated march 72 came with the car. Among other things the car was ordered with a posi, 8 track, buckets but no console. It is code 56 yellow with black interior and vinyl top and has no AC. He was disappointed in the 350 engine and lack of cutout rear bumper but thought it was fairly priced. It is pretty clean.
Nice car! Manual trans, rallye pack, non-A/C car. What's not to like?
The 3 speed stick is pretty fun to drive - I had a '68 post coupe with that setup.
He'll be itching for nice weather to arrive.
Terry
Terry
Those "Fasten seat belt" lights on top of the dash only came on late '72 cars that had the Rally pack(Tach & gauges). If you did not have the Rally pack, the "Fsb" was in the bottom of the fuel gauge pod.
I have two early '72 cars, both built before 1-1-72, both with rally pack, & both have the wiring for that light, but neither has the light.
The car looks really nice, has some very nice options and the stripes are correct W29 ones. The original hood for the car would also have blacked out 'faux louvers'. If your brother ever finds a broadcast card for this car it should show the W29 option in Box 12 under the heading "COPO & SO". If it came with the 350, check the VIN to see if it starts out 3G87J , or 3G87M. Both of those (2bbl and 4bbl) were true N10 turned down dual exhaust under rear bumper.
I'd be curious to know if his VIN is close to mine which was produced in early April of 1972. My last 6 VIN digits are 208783 and body number on the cowl tag is 442325.
Last edited by Allan R; Jan 21, 2014 at 05:23 PM. Reason: remove incorrect stmt, install correct one
Thanks again everyone, but blacked out tail light lens factory?? Wow shows you how much I know... I can get the vin this weekend. Only thing he has is the GM order sheet where you can check boxes for the options... The guy went for a tape player but only an AM radio...
Yes, you're right. I'll fix that. If it still retained the OEM hood with Faux louvers, THEY would be blacked out.
Kevin, the W29 option wasn't available until the 72 model year so yup, it would only be that year far as I know. The non W29 cars with faux louvers came with the louvers matching the lower body color accented by the silver reveal trim.
The vin is 3G87M2M212321 and here are some pictures of the order sheet. Is it possible to tell what gear is in the rear from this?
Well, the gear ratios are listed on the sheet, but none are checked. I am not sure if there was a standard default gear or not. I think that you'll have to see what is stamped on the axle tube.
http://wildaboutcarsonline.com/cgi-b...aldisplayed=50
I'd hate to send anyone to Olds 442 & W-Machines Resto Guide, as full of errors as it is.
Have to back up here. Kurt are you saying this car came with a column shifted 3 spd manual trans and someone converted it to a floor shift? I know in 72 the 442 was an option on a Cutlass and not a model. You got the appearance package when you ordered W29.
Thank you so much for posting pics of that dealer working copy order. Is it a special size or just 81/2 x 11? It's the first one of these working copies I've seen.
It's weird that the F41 suspension is checked off when the W29 option has also been.
Wow! That is fairly close to the VIN sequence on my car. Likely it was built the week after mine. Is the cowl tag build code 04A or 04B?
Bear in mind this is an order sheet. What is on a order sheet does *not* mean for certain that is the way the car came. All you can say is that this is the way the car was ordered.
The M15 is checked off. Notice that is no-charge, too. That is the standard trans for the A-bodies: a column shift 3-spd manual.
You are correct. I was thinking the W39 was a shifter and trans option, but it is just a shifter option so it would coexist with the W39. Same transmission, different shifter.
Vista Cruiser & Wagons
24
Apr 14, 2017 04:13 PM
4-ever-olds
Oct 26, 2009 08:07 AM
Congrats on his purchase
Sounds like a nice ride.
