Need Help on unknown paper found in '69 Cutlass
Old Nov 30, 2010 | 11:54 AM
jon69olds's Avatar
Hello all,
Well as you can tell I need help. I have a paper out of my car, but I don't know what it is or how to decode it if it will tell me the options that my car came with. I don't have a picture, but I did recreat it on excel. Any help is greatly appreciated. Thanks.
Old Nov 30, 2010 | 12:04 PM
crzyjef's Avatar
Could be the build sheet.. get a picture of it as you found it..
Old Nov 30, 2010 | 12:08 PM
Lady72nRob71's Avatar
Nice find!
This pretty much told the guys building the chassis which parts to use. Like use code NN rear springs, etc. The springs would all have a paper tag to identify them and they needed to pull NN for the rear for yours.
It does not tell the whole story on the build and does not say anything on the interior options, as a separate sheet might tell that.
Hard to tell some things, like if it had disc brakes or not.
If someone had a magic decoder ring, the outcome would be interesting!
Old Nov 30, 2010 | 06:21 PM
stan 65 cutlass's Avatar
wow, impressive, thats quite the excell, in the time it took you to do that you coulda walked some where and borrowed a camera, sorry dont know 69 codes but do appreciate the paperwork find
Old Dec 1, 2010 | 04:35 AM
jon69olds's Avatar
You are most likely correct. It seemed like a good idea at the time. Any clues on what it is? I am currently baffled.
Old Dec 1, 2010 | 05:13 AM
Rickman48's Avatar
I'd guess it's one of the true 'build sheets' that follow the car down down the assembly line!
Never seen one before - great find!!
Old Dec 1, 2010 | 05:14 AM
Bluevista's Avatar
Registered
It's the assembly plant build sheet.
It was used by the guys putting together the car together on the assembly line so they would know what stuff they should put on the car, like Rob and Rickman said.
Nice documentation, a few of the codes are obvious like the engines but I have no idea how to decipher the single digits and letters either, may have denoted what bin or rack they grabbed the part from for all I know.
BIGJERR
Jan 10, 2011 06:49 PM
HUSKER
Aug 21, 2010 10:08 AM
mujram
Jun 22, 2010 08:02 PM
1969w3155
Dec 23, 2009 07:45 PM
dan1s
Sep 24, 2009 12:24 PM
