need help on a phenolic carb spacer
Old Oct 20, 2016 | 09:57 PM
cobalt's Avatar
1956 oldsmobile
im thinking of switching to a phenolic spacer under my carb on my 455 to help stop some heat transfer..here is one i found..but i noticed it has four same side holes where as my aluminum one has them but the other side is shaved on a angle...does it matter the other on doesnt? and if so where can i get a phenolic spacer like that? thanks
Old Oct 21, 2016 | 06:42 AM
The spacer with angled holes is intended to adapt a square bore carb to a spread bore manifold (or vice versa). Straight holes are intended for situations where the carb and intake match. Frankly, if you need a square-to-spread adapter, just get an intake to match the carb.
Old Oct 21, 2016 | 07:06 AM
toymobile's Avatar
Joe I think he is trying to raise the carb up on the intake to help a vapor lock.
I have made such out of 2X6 WOOD, use a Q jet gasket for s pattern and in just a few minutes you can have 1 5/8" spacer.
Old Oct 21, 2016 | 07:13 AM
I got that, but he was asking about "straight holes" vs. "angled holes" and didn't appear to understand why they were different.
Old Oct 21, 2016 | 06:50 PM
I think Joe was trying to say that conversion spacers are ghetto engineering, like such.
Old Oct 21, 2016 | 07:27 PM
cobalt's Avatar
1956 oldsmobile
heres my old ghetto engineering...now moving onto phenolic ghetto engineering
Old Oct 21, 2016 | 07:39 PM
coppercutlass's Avatar
Chevy budget Olds powered
nothing wrong with a spacer. How is it ghetto engineering when its been proven to work weather making HP or helpting to keep temps down on the carb. I run an open spacer on the RPM intake on my SBO . No adapter Just an open spacer on the spread bore pad on the intake. I also use a heat sheild. Dunno if it works but it looks cool lol. Sad how any people dont know what it is.
Old Oct 21, 2016 | 09:09 PM
The spacer itself is not ghetto, using it as a bore adapter for other than short term kind of is.
Old Oct 21, 2016 | 09:16 PM
The rpm intake is spread bore. So mine is permanent lol.
62radarlove
Feb 26, 2012 12:25 PM
jhoppeolds
Brakes/Hydraulic Systems
Oct 13, 2010 06:22 AM
defiant1
Sep 19, 2010 06:44 PM
deadmanscurve
Mar 12, 2009 06:42 PM
65Delta88
Mar 25, 2008 07:18 AM
