my oil light came on help
so i changed my oil and put like 4 quarts of 10 w40 and one quart of 20 w 50. and i drove the car a few days and it just came on during a short trip. i check the oil and its still full. can you guys help diagnose this problem.
I agree to first check the sensor, but I'd at least hook up a temporary gauge to really see whats going on. Better still, is install a gauge inside the car. I put a small Auto Meter triple gauge pod in mine, and tee'd at the engine oil port, so the warning light still works. If the oil pressure's low, then time to pull the pan and check the pump, main and rod bearings. An undamped gauge will usually show if a rod bearing's going, as will be jumping around. Hopefully it's just a bad sensor, but best finding out now.
Here is the sender.
The one in this picture is big, for a gauge.
The one you have is much smaller and has one wire going to it.
72Blazerod
January 1st, 2015 11:04 AM
starr88
Tech Editor's Desk
May 23rd, 2011 05:43 PM
starr88
May 23rd, 2011 06:06 AM
