Most likely a stupid question
Old Feb 19, 2010 | 06:49 PM
71cutty's Avatar
Question Most likely a stupid question
What exactly does a msd ignition box do and is it worth me buying??? if i do buy 1 witch kind would you guys recommend??? thanks for the help im kinda new to the classic car thing so any opinions will help
Old Feb 19, 2010 | 09:36 PM
70 cutlass s's Avatar
Here is a couple of links to msd
http://www.msdignition.com/Products/..._Ignition.aspx
http://www.msdignition.com/msd6a.aspx
Old Feb 20, 2010 | 01:05 PM
depends on whether you're trying to keep the car stock; if yes leave the stock ignition in. Assuming it all works properly, it's not that hard to maintain. If not, have at 'er. Don't stop with the igntion module, you'll want to change your distributor to hei too.
Old Feb 20, 2010 | 02:24 PM
Well, MSD boxes have nothing to do with "classic cars", as they are an aftermarket add-on. MSD stands for Multiple Spark Discharge. The basic concept is that rather than a single spark, the MSD box provides multiple sparks in rapid succession. That way, if the first spark doesn't ignite the mixture for whatever reason, the second or third spark should. Many have argued that a properly tuned stock ignition will work just fine, and there is some truth in that. MSD has evolved it's products, however, and now you can get boxes that have electronic tuning of the spark advance and other features such as boost retard or NOS retard.
Old Feb 21, 2010 | 05:02 PM
71cutty's Avatar
Question
would the ignition help with performance????
Old Feb 21, 2010 | 05:15 PM
What are your plans for the car and what have you done already.
Old Feb 21, 2010 | 05:24 PM
71cutty's Avatar
truthfully i just want a bad *** street car.......i havent done much yet but next week i plan on getting a nice header and exhaust kit...... most likely a dyno max and i have b&m shift kit and 1800 stall converter......i havent done much yet but i just dont know where to start 1st
Old Feb 21, 2010 | 05:26 PM
I would start with gear in the rear end. 3.23 to 3.42 are good gears for street. You need to find out what you have and go from there.
Old Feb 21, 2010 | 05:33 PM
71cutty's Avatar
would i have to take the rear end apart to figure that out or would it say it some where.....im the second owner of the car and the 1st owner didnt really add anything to the car so im guessing its the stock ratio
Old Feb 21, 2010 | 06:03 PM
Here is a tread talking about decoding rear axle. When it comes to rear ends 507Olds is the guy to talk too.
https://classicoldsmobile.com/forums...rear-axle.html
Old Feb 22, 2010 | 06:57 AM
Not that you will notice. Be aware that there is no magic add-on that will instantly give you an extra 150 HP (well, except for nitrous). You need to buy parts that all work together at the intended RPM range and intended use. The MSD box forms a foundation for other mods that generate increased cylinder pressures.
Old Feb 22, 2010 | 04:11 PM
71cutty's Avatar
Question
so your basically saying that i dont really need it until/unless i change my cams???
Old Feb 22, 2010 | 04:16 PM
Cam it only has one. Plus a few other upgrades like higher compression pistons, heads worked, and so on.
Old Feb 22, 2010 | 04:26 PM
71cutty's Avatar
thank you.... that helps me alot... im kind of new to this but i broke up with the ol lady so this is the new love of my life......i love my cutty and i just want the best for her!!
Old Feb 22, 2010 | 04:29 PM
I have a question for you on another forum I talked to a guy a few weeks ago that had the user name 71cutty. I didn't know if you where the same guy.
Old Feb 22, 2010 | 04:33 PM
71cutty's Avatar
most likely it was me.....im a newbie
Old Feb 22, 2010 | 04:38 PM
The cool thing about this site it is focused on Olds and can post pics and share bout your car ask questions. Welcome to the site.
Old Feb 22, 2010 | 04:53 PM
71cutty's Avatar
how do you add pics.....my car is in the paint shop now but i should be getting it back by thursday
Old Feb 22, 2010 | 05:00 PM
It depends if you want to add them to a post or start an album.
This is for adding pics to a post explained by Jamesbo.
When you reply make sure you are in “Advanced” If it says post a “Quick reply” hit “Advanced”
Scroll down below the box you type in and hit “ Manage Attachments” A new box will pop up.
Hit “Browse”
The hit “Upload” and wait a few secs for the pics to up load. Then close this box.
Next you can hit “Preview Post and your pictures should be there.
There is a size limit on pics
If you mean "add pics to profile hit "user cp in the grey bar
Old Feb 22, 2010 | 05:02 PM
71cutty's Avatar
thanks.....u'll see my baby most likely by friday
auto_editor
Apr 26, 2013 05:19 PM
64Todd
May 6, 2012 11:30 AM
Tedd Thompson
Sep 24, 2010 07:32 AM
gearheads78
Dec 18, 2009 06:15 AM
donvier
Sep 24, 2008 11:16 AM
