Might As Well ?
Old Oct 24, 2025 | 12:50 PM
67VistaBlue's Avatar
Might As Well ?
Hello all,
Going to replace motor mounts on the VC (330 engine). Planning on using engine hoist to lift it up a couple inches.
Exhaust system is off, carb off, radiator is out (for cleaning).
Looks like I have enough clearance with the kick down switch and distributor to raise the engine, but figured I ask if I'm missing something.
The oil pan gasket / seals should be replaced too.
So, my MAW is question; is there enough room to raise the engine (with trans attached) to drop the oil pan without hitting the firewall?
Thank you,
Ed
Old Oct 24, 2025 | 01:24 PM
The stock pan will come out with the engine in the car. It’s a tight fit. I’d suggest reading the service manual, I’m pretty sure it’s outlined that you need to rotate the crank to a certain position to allow the pan to clear a counterweight. Id suggest removing the distributor cap as well.
Old Oct 24, 2025 | 01:51 PM
Good points, thank you.
I should probably unhook the shifter linkage too.
Old Oct 24, 2025 | 02:04 PM
Don't forget about the ground strap to the back of the passenger's head.
Old Oct 24, 2025 | 02:43 PM
Ok, thanks
I'll also look up the rubber rear main seal part number. I saw talk of it here not too long ago
MAW check the Timing Chain too. I'm pretty sure It hasn't been replaced. 97,000 miles on odometer.
Old Oct 24, 2025 | 03:21 PM
Might As Well ?
Picked this up at Harbor Freight. Will make the job easier. Looking forward ....
W-27
Jan 2, 2020 09:36 AM
deadeyejedi
Feb 26, 2017 08:31 AM
alburk
Jun 29, 2016 05:18 AM
kansjfr
Aug 14, 2015 08:50 PM
MudEye
May 29, 2013 06:07 AM
