metal Prep 70 cutlass - Surface Rust Removal
Old May 21st, 2011 | 11:54 AM
Del70's Avatar
I have a fender that has some surface rust, I have taken the DA sander down, removing 40 year old GM primer, and I still have some spots of surface rust, where a sratch went throught the primer, etc. Can the rust ever be removed,?. Will sand blasting remove it?., best primer to seal it Any ideas, tips would be appreciated..
thanks
Old May 22nd, 2011 | 08:48 AM
Del70's Avatar
Any anyone out there ever restored a 70-72 Cutlass NOS fender with some very light surface rust from scratching, and thin GM primer application. Best way to remove, seal any surface rust..thanks.
Old May 22nd, 2011 | 02:12 PM
69442C's Avatar
Depending on the severity of the rust, I would try to sand it down with 80 grit to see if that would take it out. If not, I would lightly sandblast the bad areas to get rid of the rust. Once the rust has been removed, sand the entire fender down with 150 or 180 grit. Don't worry if there are pit marks as it's not important to get rid of them at this stage. After the 150 or 180 grit sanding, apply an epoxy primer to the fender. After the epoxy is applied, spray over that with a urethane primer surfacer that has the ability to give a little surface build. Once that is dry, you can sand the fender down until all blemishes are removed. Make sure you understand the use of the paint products and how they are applied. If the pit marks are a little deep, you can apply a glazing filler to the areas and then primer over that once it has been sanded smooth.
Old May 22nd, 2011 | 02:31 PM
Del70's Avatar
thank you,
yeahbuddy
Body work
17
June 24th, 2013 10:01 AM
Delmont 88 PA
Body work
May 25th, 2012 10:28 AM
malibu406
Body work
October 3rd, 2011 07:22 PM
shaks 442 clone
February 14th, 2008 12:27 PM
t_visker
December 29th, 2006 09:59 PM
