Looking for a rear axel bearing [1967 Vista Cruiser - RW507GR]
Old August 14th, 2020 | 10:30 AM
TTW13's Avatar
Hi Guys,
I'm looking for a rear end axel bearing for a 1967 Oldsmobile Vista Cruiser - # RW507GR. Does anyone have any to buy or have sources/leads I can follow? I haven't been able to find any so any help would be appreciated.
-TTW13
Old August 14th, 2020 | 11:48 AM
N.O.R.S. versions appear on ebay periodically (though unfortunately there are none listed at the moment). I suggest you search for that p/n on ebay daily until some are listed again. Be sure to use quotes around the part number in your search, or you'll also get similar but incorrect P/Ns. No, there is no readily available alternative bearing. If you google that P/N, you'll find vendors who have them for several hundred bucks apiece.
Old August 14th, 2020 | 01:23 PM
Tri-Carb's Avatar
For those contact Brian Trick at
thetrickfamily@yahoo.com
814-440-3553
Old August 14th, 2020 | 01:36 PM
Contact Member monzaz, he can probably help or point you in the right direction
https://classicoldsmobile.com/forums...rs/monzaz.html
jimjific
August 12th, 2017 04:16 PM
vistacruiserman
Cars Wanted
February 26th, 2017 05:48 AM
Co.D62dPA
January 21st, 2016 10:28 AM
junkman454
April 29th, 2012 06:33 PM
442garage
Drivetrain/Differentials
August 27th, 2008 05:08 PM
Quick Reply: Looking for a rear axel bearing [1967 Vista Cruiser - RW507GR]
