Looking for this part can't find anywhere
Google is your friend.
https://www.ebay.com/itm/GM-10159600...-/264773248279
FYI, this is the early fuel evaporation (EFE) unit, which takes the place of the heat riser and exhaust crossover on older engines. If you can't get one, you can use the readily available gasket without the heater element, and it just means that your car will take a little longer to heat up when it's cold.
