looking for carburetor rebuild advise
I have a 1967 Toro with the Rochester 70271131 carb. After having it rebuilt, it is still leaking fuel and the rebuilder suggested that the body must be cracked - needs to be replaced. Wished I would have known that before it was rebuilt!
I recently purchased a NOS factory service replacement quadrajet. It is marked as follows:
CARB BODY IS #7035530, AIRHORN # 7032741, AND THROTTLE PLATE CARRIES #7034923. STAMPED ID ON THROTTLE SIDE IS 4447S AND IS CARTER SERVICE REPLACEMENT PART NUMBER. IN ADDITION #33679 IS STAMPED ON BOTTOM OF THROTTLE PLATE BETWEEN PRIMARY BUTTERFLIES. DATE CODE IS C0 WHICH WOULD INDICATE MARCH OF 1970.
So here is my question. Would I be able to use this carburetor to "create" a 7027131 by replacing the main jets, primary rods, and secondary rods using the correct parts for a 7027131?
Any advise would be appreciated.
Thanks,
Tom
Thanks,
Tom
ibfurloughed
September 20th, 2010 06:10 PM
yeahbuddy
June 1st, 2010 05:38 AM
