Lifting Body from Frame
Just a question for those who have lifted the body from the frame of a late 60's/early 70's Cutlass/442. Besides the body mounts, are there any other points that need to be disconnected? Assuming the linkage and all wiring and wirewall items are removed first of course. I thought for some reason the floor pans were welded to the crossmember. Is this correct?
Sena
Sena
Body Lift
I just took my 1970 442 Convertible off of its frame.
There were (8) body bolts and (2) sets of spacer bushings.
Some cars are a little different from my research but other that the body bolts and any obvious wiring, linkages, etc., it will lift right off.
Sean
Some more to add in - rear upper control arms, rear shocks, e brake cable. You might want to remove the rear bumper also so the filler neck on the fuel tank doesn't bind when lifting the body?
Not exactly sure what you mean by linkage, but Chris has you covered for a lot of that.
Sean
I used a chain hoist in the front body mount pockets at the bottom right and left edge of the fire wall and a 4x4 across the trunk floor with a hydrolic jack, raising the font and back up a little at a time, then when high enough, i inserted a 5' piece of square steel through the wheel rear wheel house onto saw horses. Rolled the old frame out the back and the new frame under the front. The whole process took an afternoon. The hard part was some of the captured nuts came loose inside the body, i had to cut small windows behind the rear bumper to get a wrench on them. I made cover panels that are screwed in jsut in case i need to access them again, they cant be seen with the bumper on.
space was limited in my garage too. so i used blocking lifted car and frame together then put the blocking under the seat reinforcements in the floor and dropped the frame.
then i used 4 in by 3/8 thick angle 8 ft long and lifted angle with two jacks just outside of frame then sat angle on 120 lb grease drums. then rolled frame out door.
e129745
Suspension & Handling
April 17th, 2014 03:02 AM
delta_88_germany
May 16th, 2013 04:15 AM
Dan Wirth
November 11th, 2009 12:55 PM
