last repair ?
last repair ?
been restoring a 67 2-door post for about two years. (only intended to repair the front floor pans, but things got out of hand). about to attempt the last repair, replace the lower front windshield track. any tips or advice before I start cutting? thanks in advance for any help. txtom
![Big Grin](https://classicoldsmobile.com/forums/images/smilies/biggrin.gif)
Seriously, do you know that there's a patch panel for this area? Most vendors list it as a 66-67 Chevelle part, but it's the same on all the A-body cars.
"Last repair." - One of the biggest oxymorons in the old car hobby. ![Big Grin](https://classicoldsmobile.com/forums/images/smilies/biggrin.gif)
I have a severe case of the "mightaswells" right now and it is not getting better!
Torn rear seat = new carpet, sound deadener, power windows, new door panels, new amp, etc......
![Roll Eyes (Sarcastic)](https://classicoldsmobile.com/forums/images/smilies/rolleyes.gif)
Tom I have the same car. also with the same patch section on my cowl and channel area. replace the least amount of metal as possible is the key from the experiance I have had. lucky for me my areas are small so mine will be fairly easy to do. post some pics if you can I know there are a few pro body guys on this board
New Thread
Open the forum you want, look at the upper left hand of the list, right on top. There should be a blue box that says "New Thread" If your not seeing that there may be a hiccup in the system. John
gearheads78
May 12th, 2024 09:36 AM
