kill switch
Old Sep 3, 2013 | 09:00 AM
Switch Blade Betties's Avatar
kill switch
has anyone installed a kill switch on a 55 olds 88? im looking to do that. any help would be great!
Old Sep 3, 2013 | 09:11 AM
Why? Do you leave it unattended?
Old Sep 3, 2013 | 09:25 AM
Octania's Avatar
with any pts-ign engine, that will be super easy.
Run another wire from the coil terminal that goes to the points, thru your secret switch, to a ground. This effectively makes a parallel point contact that stays closed as long as you say so, preventing spark from happening.
I assume radio noise is not an issue on a '55- that coil extra wire will be a very nice radiating antenna. You can shorten the "antenna" by putting a relay near the coil, but that violates the KISS principle.
I have a nice system that I devised which is a little more complicated, but it automatically arms, prevents driving off, and requires a secret device to disarm. Inquire for details.
theoldsrocket
May 11, 2011 01:14 PM
Rickman48
Mar 23, 2011 01:03 PM
New'n72
Jan 30, 2009 01:42 AM
projectheaven
May 6, 2008 06:45 PM
mm89olds
Apr 6, 2006 11:03 AM
