Keyed power source
Old Apr 10, 2019 | 12:27 PM
roosgunboss's Avatar
Keyed power source
When I had my restoration done I had the company put in after market guages. Unfortunately, they got power from the fuse block on the BAT terminal so they were pulling a constant drain from the battery. Suggestions on a better spot to pull keyed power from?
Old Apr 10, 2019 | 01:13 PM
don71's Avatar
same but different
At the fuse box, look for IG that'll give you power with key on. Hope fully, its not all ready in use.
BTW, its really helpful if you tell us exactly what car are you working on.
Old Apr 10, 2019 | 05:06 PM
Yes, the IGN terminal is a switched power supply and should be close to the BAT terminal. If something is already plugged into the IGN terminal, just get a dual spade terminal and you can then plug both things into the IGN port.
Old Apr 10, 2019 | 06:13 PM
If your just looking for a keyed source for a volt meter, then splice into the radio power wire.
Townie
Jan 28, 2020 07:18 AM
rand5204
Sep 16, 2019 05:12 AM
Danny Boy
Aug 22, 2016 08:11 AM
ostie13
Sep 4, 2014 07:56 PM
Macadoo
Aug 5, 2014 06:52 AM
