Jack and Jack Stand Placement
Old Dec 1, 2022 | 07:06 AM
PM70's Avatar
Im think about getting a hydraulic jack and jack stands to use qitg my '70 Cutlass Convertible. Where is the best place to position the jack and stands, front & rear? I searcehd some answers here in the forum and have a pretty good idea, but would like confirmation. Is there drawing or anything? Thanks!
Old Dec 1, 2022 | 07:47 AM
Read the owner's manual, it's in there. Short version is there are welded large metal frames behind the front wheels and in front of the back wheels to use. There's even round holes for pegs on lifts, that's the precise target.
Old Dec 1, 2022 | 08:03 AM
It really depends on what you're doing and if the jack stands will be in the way. Jacking up the front use the front xmember, jacking the rear use the center of the rear differential. Jack stands can be placed under the frame just behind the front or just forward of the rear tires. They can also be placed under the front lower control arms or under the differential tubes.
Old Dec 1, 2022 | 08:47 AM
redoldsman's Avatar
Proud Viet Nam Veteran
Once you have the car on jack stands, try and shake it. It is better for it to fall then than when you are under it.
Old Dec 1, 2022 | 09:28 AM
OLDSter Ralph's Avatar
once you have the car on jack stands, try and shake it. It is better for it to fall then than when you are under it.
x 2
Old Dec 1, 2022 | 10:53 AM
Andy's Avatar
x2
Old Dec 1, 2022 | 03:56 PM
71Convertible's Avatar
Check the distance the jack will lift (fully lowered to fully raised), many newer jacks may not give enough.
Old Dec 1, 2022 | 04:26 PM
That is where a section of 4x4 comes in handy.
Old Dec 1, 2022 | 04:46 PM
The Chassis Service Manual shows you EXACTLY where the jacking points are.
Bfg
Oct 9, 2020 12:45 PM
PM70
Sep 9, 2019 07:34 AM
Mark57
Dec 4, 2016 04:47 PM
455man
Aug 9, 2013 10:33 AM
