Installing rear armrest covers
Old Feb 27, 2012 | 02:51 PM
ELECMAN's Avatar
Is there a certain way to install these covers,do they get glued on like paste or sprayed on.Do you have to install foam.I just ordered them from opgi today.
Old Feb 27, 2012 | 05:52 PM
Lady72nRob71's Avatar
If there is no padding with them, you will need to provide your own.
Basically a thin layer of polyester fiberfill was used on the outside with a thicker layer on the armrest part. This is similar to that is at the tops of the door panels.
A little spray adhesive can be used to hold the fill on. Place the fill on but do not press it hard. Let dry for an hour before covering.
The vinyl cover would be glued on only on the backside with 3M 8090 trim adhesive.
The fill allows some poofiness to hide imperfections in the metal and providing a more luxurious look and feel.
Old Feb 27, 2012 | 08:06 PM
70Post's Avatar
Rob you've been watching too many old car commercials
Follow Rob's advice and you'll be bragging about your Olds interior as well.
http://www.youtube.com/watch?v=vIL3fbGbU2o
Old Feb 28, 2012 | 06:21 PM
ELECMAN's Avatar
do you go with 1/8 or 1/4 poly foam size
Old Feb 28, 2012 | 07:34 PM
IF possible, I would go with polyester fiberfill padding. It will last longer than foam, which could deteriorate in automotive environments. Sewing / craft / fabric stores should have it. 1/8" should work if using foam, use 1/4" for polyfill, as they both compress differently.
Old Mar 1, 2012 | 05:10 PM
ELECMAN's Avatar
Thanks Rob
Old Mar 1, 2012 | 06:39 PM
Al Graaf's Avatar
Formerly "Shimmer"
Forgot all about the Corinthin (sp?) leather Patton. That was good
AL
Sunshn
May 11, 2015 10:30 AM
hilbily
Nov 10, 2014 03:26 PM
JJSCUTLASS
Feb 22, 2013 07:59 AM
kszew
Feb 21, 2011 10:39 AM
sklbndt
Dec 24, 2009 05:22 PM
