Idle Problems
Old Jun 18, 2017 | 06:16 PM
Jyelinek's Avatar
Idle Problems
Hello,
I have a 1968 Oldsmobile 442 stock motor (400) with a edelbrock performer manifold and a edelbrock thunder series 650 carb. When I start the car it will idle perfect, smooth, I can drive it around and when I come to a stop light it may start having idle problems and will run rich. Also sometimes it may not do that at all. Today when I drove it, it drove just fine with no problems, I stopped and parked it for a while and when I got back into to start it I had problems keeping it at idle and when I would let off of the gas pedal the car would just die. I was able to get it home and when I pulled into my driveway it was running just fine. Can anyone help with this problem? Anybody have any experience with this carb? Thanks for taking a look.
Old Jun 18, 2017 | 07:07 PM
Gary M's Avatar
I had a similar issue with a quadrajet and mine was trash in the float needle. Today's fuel ate the body of the carb in the inlet past the filter but yours is not a QJ. Sounds similar though.
Old Jun 18, 2017 | 11:55 PM
shiftbyear's Avatar
Gary may be right, fuel pressure may be a problem also. If the carb is new I would take the top off and have a look, quality control may have overlooked something. Good luck.
Old Jun 19, 2017 | 04:40 AM
Check your fuel pressure and float levels.
chasman414
Jun 25, 2020 07:05 AM
Seff
Sep 20, 2012 04:46 PM
73rocketship
Jul 6, 2012 06:45 AM
thatguy32567
Feb 26, 2010 07:37 AM
llj537
Ninety-Eight
Apr 16, 2008 07:42 PM
