I think my '91 Oldsmobile is about dead.
Last month I started this thread here: https://classicoldsmobile.com/forums...-question.html
I was having issues with the engine shaking while running. I thought it was the catalytic converter... So, I cut it off and replaced it with a straight pipe.
Still shakes.
I checked the sensors on the intake last night, and they still look fairly new. My father drove the hell out of that car and because of this replaced much of the engine. I had replaced all the spark plugs last year and checked them last night. They seem to be fine and firing.
The oil has me a bit concerned though. It looks like river mud and has a quart too much in the pan. If anything it should be low. Oil doesn't magically appear. (And if it does, you can bet I'm selling the car to Opec and retiring).
The radiator is full of nice transparent green antifreeze, but the car is going through gasoline at an alarming rate. I assume the fuel is somehow getting into the pan.
I didn't want to have to get rid of my car. It was a nice daily driver for the last 5 years. Right now I'm having to drive my '57 around town, and it's not 100% itself. (It's very hard to stop).
Any ideas of what is causing this? (Other than the 300,000 miles)
Still shakes.
![Stick Out Tongue](https://classicoldsmobile.com/forums/images/smilies/tongue.gif)
Does the oil smell like gas? I've had a couple fuel leaks to the crank case and it seems to thin the oil out the river mud sounds more like water.
The radiator is still full but is the overflow bottle still full ? That could account for a quart of coolant.
Honestly, I'm not sure about the smell. I did try, but I was unable to determine if it was gasoline in the oil. I'm thinking about putting some in a small pan and seeing how fast it burns. While it looks like river mud, it flows like water. My sense of smell has obviously been damaged by years of changing the diapers of my three kids.![EEK!](https://classicoldsmobile.com/forums/images/smilies/eek.gif)
I didn't even think of the overflow on the radiator, yes, it is empty, but I've not noticed the tell-tail signs of burning antifreeze.
Mechanical engine-mounted fuel pumps have been known to leak fuel into the oil. My mom's 307 did this once. Oil looked clean, but it flowed like water and the level increased.
Your car looks to be EFI, with an electric fuel pump. Recon it is running EXTREMELY rich? Extra gas can soak in through the piston rings and the car would run like crap. If this was the case, the SES light should be on.
Fuel pressure regulator maybe??
Oil looking like sludge makes me wonder though. I would think coolant would be getting mixed in for it to turn THAT color...
If so, head or intake gaskets may be needed.
![Roll Eyes (Sarcastic)](https://classicoldsmobile.com/forums/images/smilies/rolleyes.gif)
![Frown](https://classicoldsmobile.com/forums/images/smilies/frown.gif)
Hi Jon
I have a 93 olds 98 touring sedan with 120K and had a similar prob, the bucking action was the crank sensor behind the harmonic balancer and the intake gasket leaking antifreeze into the oil pan is common.If you were burning the antifreeze the check engine light would be on (o2 senser does't like antifreeze).
I put a new harmonic balancer on it a few years ago, but you may be right about the sensor. I let it idle for about five minutes about an hour ago and the "Low Coolant" light came on, it hadn't done that before, but none of the other lights did.
I assume it is antifreeze in the oil, but it sure doesn't look like it. No foam, clean plugs, and the oil doesn't seem to separate when left to sit, but the antifreeze is going somewhere. It's not burning it
I had a Monte Carlo that blew the intake gasket. It ate O2 sensors.
I thought it may have been one of the sensors on the intake because of the amount of gasoline the car is using. I could literally see the needle drop as I drove around for about ten minutes trying to figure this out. (It took about an eighth of a tank to go just a few miles).
It's the strangest thing when this began. I was on my way to work when I decided to stop and get a coffee. I let the car idle outside, and when I got back in, it wouldn't run worth a damn.
Once I got to 30 mph, it straightened out and stopped bouncing around.
Now, it doesn't matter how fast I go, it runs terrible.
Even though it's a 1991, it's still much newer than what I'm use to working on, or even have diagnostic tools for.![](http://www.digitalwebbing.com/forums/images/smilies/tounge.gif)
I'll keep tinkering with it, thanks for the ideas!
Once I got to 30 miles per hour, it straightened out and stopped bouncing around.
NAS Backyard
November 21st, 2019 08:57 AM
