Hurst shifter id help
Old Jan 5, 2016 | 03:50 PM
brandon reynolds's Avatar
Ok are either of these shifters correct for 70-72? Is there a way to tell the year? The one that says hurst had a 7305 non console handle and the one that says competition plus had a 7169 console handle in it. Thanks for your help. Brandon
Old Jan 5, 2016 | 04:14 PM
allyolds68's Avatar
As long as the shifters were original these are the applications
Old Jan 5, 2016 | 04:16 PM
Mike sorry if i wasnt clear i understand the handles but was wondering about the shifter bodies themselves. Years? Correctness for 70-72. Thanks brandon
Old Jan 5, 2016 | 05:13 PM
junior supercar's Avatar
do either of the shifter bodies, like on the front, have iirc, 3138 on them? those are correct for a wide range of GM and Chrysler (and AMC?) vehicles, including the 70-72 you are asking about.
Pete Serio's Hurst shifter books, vol 1 and vol 2 are great references.
Old Jan 5, 2016 | 05:14 PM
marxjunk's Avatar
take a pic so we can see the lever receiver..is it straight or angled...
no one has decoded the numbers you show with consistancy, it contains partial date code and part number...but the camaro guys have just about got it figured out...for camaros...
those both look like the correct mechanism...but how that handle sits in there is the clue...
and they are the same 70-72 console or not...
Old Jan 5, 2016 | 05:18 PM
Mr Shifty Sidney's Avatar
Factory shifters did not have a threaded hole for stop adjustment and the handle receivers should be tilted as shown in this pict from Terrys website.
http://highoctaneauto.com/newpage66.htm
Don W
Old Jan 7, 2016 | 02:24 PM
Ok so both shifters are angled the same. Which one is correct for a 71 442? Thanks brandon
Old Jan 7, 2016 | 02:30 PM
Brandon,
Rotate those shifters and post a picture. There should be some numbers on there. They both "look" correct to me. Maybe someone with more knowledge will chime in.
Don W
Old Jan 7, 2016 | 03:44 PM
marxjunk's Avatar
yeah they are right...those are cutlass and trans am/camaro style shifters...
3138 is prob the shifter housing number..but unless you are a numbers guy it doesnt mean much
Old Jan 7, 2016 | 04:22 PM
Don rotate which way? Ok so they fit my application but one just says hurst and on says hurst competion plus, is one correct for 71 and one not? Is the other early or later? Thanks brandon
Old Jan 7, 2016 | 06:17 PM
Sorry, rotate 180' and there should be some numbers on there. There will probably be a 3138 stamped on there like Supercar mentioned. May be some other numbers as well. I do not know which is correct for 71. Now you have my curiosity up. I have a 72 4 speed Cutlass that I think is original. I will try to get a look at it.
Don W
Old Jan 8, 2016 | 04:13 AM
ok I flipped them over and it does say 3138 on the other side. so all my research (mostly camero sites) says that hurst competition plus was 70-72 and hurst was from 73 on. so it looks like i'll be redoing the competition plus for my 71.
67442nut
Sep 16, 2017 01:23 PM
marxjunk
Jun 12, 2014 12:34 PM
scrappie
Apr 5, 2013 02:32 PM
69CutlassAlex
Feb 9, 2012 05:26 AM
olds4life
Feb 27, 2009 08:54 PM
