hub assy
hub assy
hello all,
long story very short.. I am putting disc brakes on the Cutlass before I drop the 400E in... one hub works fine with the Scarebird brackets.. one hub is the hub that use to have a drum pressed on.. I need one hub 68 BOP I know works, I am sure others will as well.. if anyone can help me out, that would be great... thanks
john
67 cutlass
"just one to thank all those who helped out... "
john
67 cutlass
hello all,
john
67 cutlass
john
67 cutlass
And if you are worried about 14" wheels, the factory 10.75" disc brakes came with 14" wheels.
Joe, thanks for the input, I was not very clear on what was going on.. so, I will try and clear it up just a bit... I am NOT doing a kit conversion per say... I got a set of brackets from Scarebird brakes... these brackets will and do allow me to use off the shelf parts to do the disc brake conversion... no changing out spindles, no major work involved at all.. brackets bolt up, then any A body 69-72 caliber set-up, rear rotors off 79 to 81 trans am, master-cylinder front disc rear drum.. about 300.. give or take... my problem was at some point in her life someone did a front brake job on the ole wheel hub press on drum, the drums must have been bad, so they pressed them off drilled out some new drums to slip over the longer big shoulder stud... and the only thing I can think of is that they screwed up the other hub when they tried to press of the drum, replaced it with a wheel hub that takes the push on drum... I wanted to make both wheel hubs the same, so that the studs would be the same on both wheel hubs... and I got the hub from Scott, (thanks) hopes this clears everything up...
marxjunk
February 24th, 2015 06:45 PM
Eightupman
November 25th, 2012 07:22 AM
