How are the vent pull knobs removed?
Old Jul 31, 2017 | 05:41 AM
PM70's Avatar
How are the vent pull ***** removed?
Bought replacement lower vent ***** for the yellowing ones on my 70 CS, but can't seem to get the old ones off. What's the trick?
Old Jul 31, 2017 | 06:52 AM
442Harv's Avatar
I put a rag on them, and use a pliers, or vice grip, but, if there old originals, they will probably brake.Also the new one will probably be to loose, and have to glue them on.
Old Jul 31, 2017 | 01:57 PM
Toms cutlass's Avatar
I cracked mine off with a BFH on a piece of wood backing. Broke off clean. Wear eye protection.
Old Aug 1, 2017 | 05:55 AM
PM70's Avatar
Why is nothing simple? Ok, thanks for the tips... Maybe I'll just saw them off.
Old Aug 1, 2017 | 06:30 AM
Because nothing difficult is ever easy
Old Aug 2, 2017 | 01:27 PM
RocketDevo's Avatar
You need to remove the kick panel and then remove the handle assembly. The plastic retainer will otherwise break that holds it to the kick panel, making it useless. They are delicate.
Old Aug 2, 2017 | 01:42 PM
Yes, good point. I completely removed all 4 vent cables from the vents and kick panels first, then cracked the plastic chrome ***** off.
matt68F-85
May 17, 2017 06:43 PM
84oldsDelta88
20
Jan 12, 2016 01:36 PM
DRXOLDS
Oct 21, 2013 05:48 AM
GothamCity
Feb 4, 2009 12:15 PM
Oldsfan
Dec 29, 2006 05:52 AM
