How to remove radio
Old Apr 29, 2025 | 10:18 AM
1968delta88gazhog's Avatar
Tim (Gaz Hog)
How to remove radio
Not to hijack the thread to hard - but does anyone have any tips on pulling the radio from the 68 Delta 88?
I have the CSM on CD - I can only see the one screw - from below the head-unit.
How hard to pull the ***** to remove them?
Is there another screw inside the ashtray from below holding this thing in place?
Old Apr 29, 2025 | 10:28 AM
jaunty75's Avatar
Just pull the ***** off. I think there are nuts on the **** shafts that tighten against the dash plate that need to be removed, and you'll see them when you take the ***** off.
I don't think there's any other screws except the main one at the rear (I think) that attaches via a bracket to the chassis.
Old Apr 29, 2025 | 10:32 AM
OLDSter Ralph's Avatar
You may need a "thin wall, deep well" socket to loosen those nuts on the **** shafts.
Old Apr 29, 2025 | 01:56 PM
I moved your stuff to its own thread.
Old Apr 29, 2025 | 02:23 PM
66_Jetstar's Avatar
Based on what I've seen, most folks use an axe...
Hogan
Apr 18, 2024 11:53 AM
davoaz
Jul 7, 2014 02:04 AM
Tiberian Fiend
Oct 1, 2012 04:53 PM
Finn5033
May 24, 2012 09:36 AM
Dant
Jul 31, 2011 09:12 AM
