how much power can i build from this 350??
Old December 10th, 2016 | 02:21 PM
Beenz's Avatar
i have a 1969 5.7 with number 5 heads ,i have 10.1 comp on all the valves ,it came with a 2bbl ,i just up graded to a edelbrock performer intake and performer carb ,stepped up the old points to electric and new plugs wires cap rotor ,so how much power do you think i have now ? and how much more can i get with a mild cam and headers ? what can i do to these heads ?
Old December 10th, 2016 | 04:07 PM
Olds442redberet's Avatar
No comment. I just want to tag this thread so I can follow along and learn. I have a motor just like your's.
Old December 11th, 2016 | 12:59 PM
The factory specs for the 1972 350 show a 40 horsepower and 25 pound-feet increase going from 2 bbl single exhaust to 4 bl and dual exhaust, so I imagine there would be a similar increase on your engine. In todays numbers that is probably around 200 to 240 horsepower.
Old December 11th, 2016 | 01:10 PM
coppercutlass's Avatar
Chevy budget Olds powered
I dont think the 2bbl came in a 10 to 1 compression. But you will at best have appx. 8.8 to 1 compression. 69 #5 heads have normally in the range of 68 cc's not the 64 cc's most think. The 2bbl engine came with 14 cc dished pistons. You can build a stout little runner with that engine. I had a 73 350 which also had 14 cc dished pistons and 72 7A heads with a comp 260h cam , headers , edelbrock intake hei distributor th400 and 2200 stall with 3.73 gears power my car to a 13.86. The heads where all stock the short block was all stock minus the cam. Everything was just freshened up.
based off the wheight and mph the car ran in the 1/4 mile with that combination it say's i was making 263 hp at the wheels. i think those online calculators can be a little happy but it was an honest 300 hp to the fly wheel combination i think.
currently engine is appx 370 ish hp but calculator say's 394 hp to the fly .
Old December 11th, 2016 | 01:18 PM
Beenz's Avatar
i tested all the valves
i compression tested the all and they are all 10.1 two valves read at 10.0 hmm im wondering if the revious owner made some engine mods ..
Old December 11th, 2016 | 01:21 PM
m371961's Avatar
The answer to "How much power can you build from this 350?" is the question:
How much money do you have?
Old December 11th, 2016 | 01:25 PM
Beenz's Avatar
minimal ha
not trying to shell out a lot of cash ,but really feeling it out to see if its worth putting any cash into
Old December 11th, 2016 | 01:26 PM
Perhaps. These engines have been around long enough to where things could have been changed. If you do have 10 to 1 compression then you will need a healthy cam and need to run 93 octane. My current combo is 10 to 1 compression .,i would not run a cam smaller than 220 duration @ .050 lift. My cam is a 233/241 duration which is about as big as i want to run with my combination.
Old December 11th, 2016 | 01:28 PM
I have less than 4k in my 355 and it runs 12.40's in the 1/4 mile it was built with swap meet parts , left overs and parts some guys would never try out like the prw ford roller rockers i run. Just depends how you wanna go about it. The engine i have would cost over 6k to build normally but i use used parts i know are good and do all my own work minus machining.
Old December 11th, 2016 | 02:18 PM
Beenz's Avatar
i am doing a similar budget build ,ive been trading and bartering for parts and doing all my own work
Old December 11th, 2016 | 02:21 PM
Good luck. The quality is all in the details. measure everything and inspect everything.
Old December 11th, 2016 | 02:45 PM
The only 2bbl 350 motor offered in 1969 was the 9.0:1 L65 motor (second column from the right).
Old December 11th, 2016 | 02:48 PM
What does this mean, exactly? How did you determine compression ratio from a PSI number on a compression tester?
Old December 11th, 2016 | 08:29 PM
w-30dreamin's Avatar
71 & 72,now I want a 68
I'm glad you asked this question,I've been wondering the same thing.
Old December 12th, 2016 | 08:33 AM
1970-W30's Avatar
I'm guessing the original poster is dividing compression psi results by atmospheric pressure of approximately 14.7, to come up with the 10 to 1. A 147psi compression reading, typical of a low compression stock cam 350, is 10 times atmospheric pressure, could wrongly make him think it has 10to1 compression. Just a guess on my part.........
VinMichael
December 30th, 2014 05:48 AM
molasses4masses
January 13th, 2014 10:04 AM
Big_Body_Olds
May 5th, 2013 02:35 PM
70cutlass350
July 31st, 2012 01:11 PM
Motorama
December 6th, 2006 08:56 AM
Quick Reply: how much power can i build from this 350??
