how much oil?
Old Apr 15, 2015 | 07:28 AM
fatback's Avatar
how much oil?
just got my new owners manual for my 55 88, it says 6 qts. of oil. how much oil do yall run?
Old Apr 15, 2015 | 10:17 AM
D. Yaros's Avatar
Do not have a 55. That said, I would have 6 qts. on hand at oil change time, put in 5 qts. Run the car a bit to fill the filter (if it has one) and then check the oil level. Take whatever action is necessary after checking the level to get a FULL reading on the dipstick.
Old Apr 15, 2015 | 11:15 AM
redoldsman's Avatar
Proud Viet Nam Veteran
I have changed my 54 and it has a filter but I don't remeber 6 quarts. I would do what D.Yaros suggested. I have added a bottle of ZDDP so that probably threw me off.
Old Apr 15, 2015 | 11:22 AM
fatback's Avatar
dip stick says full with 5. just wonder if I have the right dip stick?
Old Apr 16, 2015 | 12:16 PM
D. Yaros's Avatar
Without reason to suspect otherwise, go with the dipstick reading is my counsel.
Old Apr 16, 2015 | 03:23 PM
ignachuck's Avatar
Frank Ignachuck
Should be 5 quarts.
Old Apr 16, 2015 | 06:18 PM
Ozzie's Avatar
Post
Page 22 of the 1955 Olds owner manual says there's 5 quarts in the pan and 1 quart in the filter. Page 2-6 in the 1955 Olds shop manual says the same thing. In those days the full flow oil filter was optional equipment. My '55 has the filter and requires 6 quarts to bring the level to the "full" mark on the dipstick after doing a complete oil change (including the filter). Oldsmobile documents indicate that the 5+1 amount was used through the 1957 model year. Beginning in 1958 it was reduced to 4+1 quarts. Recheck your circumstances. If you haven't known the vehicle since new, someone may have changed the dipstick. I've known mine from the start; the quantities, manuals, and dipstick all agree.
Old Apr 17, 2015 | 02:46 AM
ignachuck's Avatar
Frank Ignachuck
You nailed it Ozzie. I forgot about the optional oil filter element which needs a quart when replaced.
Old Apr 18, 2015 | 07:34 AM
fatback's Avatar
Thanks fellers, I must have the wrong dipstick. since I have a noisy lifter, I think I will add a qt. of oil treatment.
Old Apr 18, 2015 | 07:56 AM
Tedd Thompson's Avatar
Doubtful that the oil level being one qt low would have anything to do with the lifter noise but my stick measures 19 1/2 inches from tip to stop and the full line is 3 1/8 inches from the bottom to the full mark. you might check it out before you add to much oil. ....Tedd
Old Apr 20, 2015 | 05:22 AM
fatback's Avatar
Ted, if it aint too much trouble, the next time you get a chance, could you measure how far your dip stick housing sticks up above the block? thanks
fatback
Old Apr 20, 2015 | 07:39 PM
fatback
Sorry fatback someone else will have to get you that measurement. I'm still recovering from my knee surgery and I can't kneel on ether knee or stand bent over for any length of time....Old age sucks but is remarkable better than the alternative... I think....Tedd
molasses4masses
Jan 13, 2014 10:04 AM
BradyB
Sep 25, 2012 09:03 AM
jasmit29
Sep 14, 2012 08:34 AM
RayJ
Sep 12, 2012 04:44 PM
