How do you do it?
Old Jun 25, 2012 | 06:42 PM
Redog's Avatar
How do you do it?
How do I pull a rear end from a car at the U-Pull-It?
Just read "J"'s post about the 73-77 Cutlass rear fitting my 85 Delta, but I'm also looking at the 91-96 Impala/Caprice.
I want a posi, but I don't want to pay $500 for it off CL. Also If I get the Impala/Caprice rear, I'm swapping the axles out to have the 5x4.75 bolt pattern. I don't believe I'll have to do that with the Cutlass rear
Old Jun 25, 2012 | 07:22 PM
Oldsmaniac's Avatar
The better U pull yards have the cars up already. The low budget ones you need to jack yourself and find stuff, usually wheels to prop the car up so you can get under. Always be safe, bring plenty of spray oil, wrenches, hammers, saws and general tools of destruction. Bolts dont always come loose!
Old Jun 25, 2012 | 07:53 PM
You might also want to take a couple of jack stands with you for when you drop the axle. What Oldsmaniac said about the 'better yards'. Most of the Pick Your Part yards are like that. You can also check on line with them now - they have their inventory posted and also have an on line price list.
Old Jun 25, 2012 | 09:38 PM
Lady72nRob71's Avatar
Maybe ask the yard first. Some have rules against jacking or cutting with power tools.
If they want to make the sale, I am sure they can work something out. They might lift the car with a forklift for you or something. I saw this done at a yard near me.
Old Jun 25, 2012 | 11:32 PM
Rickman48's Avatar
Use a rechargeable Sawsall - that's how they're getting cats off parked cars in Chicago!!
Old Jun 26, 2012 | 06:20 AM
Or you can see what they will charge to pull it and drop it into the back of your truck. It's 10 min's with a torch.
Old Jun 26, 2012 | 06:46 AM
coppercutlass's Avatar
Chevy budget Olds powered
i do it on my back. That is taking the rear end out lol. Sorry i saw the door wide open . most yards wont charge much the u pull it's i beleive wont take em out for you the local ones wont but the other local yard charges 15 bucks and they usually use torches. the yards further south dont charge to take parts off. Depends what around you.
Old Jun 26, 2012 | 07:23 AM
66400's Avatar
As a bonus 76-77 Cutlass rearends are equipped with 11" drums.
As a general rule of thumb Non-police/non stationwagon standard duty 1977 and newer Caprices will will have 4 3/4 bolt pattern.
Henry
Old Jun 26, 2012 | 08:00 AM
Run to Rund's Avatar
You can sawzall the conntrol arms, or bring a battery powered impact gun for the bolts. I did them with hand tools, not pleasant. You have to push out the clips for the e-brake cables at the frame, detach from the intermediate cable. Be careful as the rear will try to pivot on you once the upper arms are off. You can cut the brake hose above the pumpkin.
Old Jun 26, 2012 | 08:04 AM
sorry 66400 but 95's had 5x5 bolt pattern. I had a 9c1 caprice and made that mistake when i ordered wheels i got 5 x4.75
Old Jun 26, 2012 | 08:49 AM
lshlsh2's Avatar
71 cutlass convertible
A thought go to your local lumber yard and get some 6x6's or 8x8's chop the up into 2 to 3ft pieces and use them to hold up the car. That way when you are done you can leave them and not try and figure out how to drop the car and get your jack, jack stands etc. out from under the car.
Larry
Old Jun 26, 2012 | 09:01 AM
Larry
Or just round up some loose wheels laying around the yard. After building a gazebo in the back yard, I was amazed at how costly lumber is now!
Old Jun 26, 2012 | 09:20 AM
chadman's Avatar
I saw it posted before but I will resay it, BATTERY SAWZALL! That and a good set of side cutters to cut the parking brake cables and brake hose.
Old Jun 26, 2012 | 09:55 AM
Octania's Avatar
Control arms: BATTERY SAWZALL!
brake hose: BATTERY SAWZALL!
parking brake cables: Battery powered 4" grinder
Done in 5m.
If you don't have these tools then borrow, rent or buy [good ones with cajones]. You will find many uses for them.
http://www.factoryauthorizedoutlet.c...FYhM4Aod0GSpww
http://www.amazon.com/DEWALT-Bare-To...8+volt+grinder
Old Jun 26, 2012 | 10:31 AM
All 91-96 cars were 5x5.
Old Jun 26, 2012 | 10:59 AM
DeltaPace77's Avatar
As mentioned, the large mounting bolts will be the biggest problem. Instead of getting all kinds of battery tools, maybe just rent a generator for the day, and use the tools you already have. Always a good idea bringing a friend along, for giving a hand and safety reasons.
Old Jun 26, 2012 | 12:10 PM
Redog's Avatar
The yards I go to only allow trolley jacks. No car jacks, no jack stands.
I've seen the wheel trick for getting wheels off all the time. I've see a few FWD cars propped WAY up to pull the transmission out too. I try to stay away from those cars. I pulled an inside rear view mirror out of a Grand Am like that. Totally did not feel steady at all.
The one yard used to have a "u-pull-it" and a "we-pull-it" price for larger items. However that yard is under new managment and is really trying to compete with the other yard I go to more often now. Cars are so close together. I pulled a rear bumper off a Caddie and I kept hitting the Chevy in front of it. What a PIA.
They filmed a reality show at that yard to and it's supposed to be on some show soon. The Junkyard is called "Junkyard Barbie's" in Morrisville, PA
Old Jun 26, 2012 | 08:07 PM
66400's Avatar
Note that my info
"As a general rule of thumb Non-police/stationwagon standard duty 1977 and newer Caprice will have 4 3/4 bolt pattern."
A 9c1 is a police car hence the 5" bolt pattern
Henry
Old Jun 27, 2012 | 10:40 AM
Redog's Avatar
Originally Posted by 66400
Note that my info
Henry
This is true, but the 5x5 bolt pattern Caprice/Impala rear is a posi (G80) with 30 spline axles. The 4.75 BP rear is an open carrier with 28 spline axles Both are 8.5 rears though
Are all the 73-77 Cutlass 28 spline rears?
Old Jun 27, 2012 | 11:51 AM
66400 the made the aluminum lace wheels for caprice classics not 9c1's in 5x5 bolt pattern too. http://www.ebay.com/itm/15-91-92-93-...e8bd9e&vxp=mtr i screwed up on the way i responded . But even non 9c1 cars had the 5x5 bolt pattern.
70 cutlass s
Nov 11, 2014 08:17 AM
Ranzan
Paint
May 27, 2010 05:25 AM
71cutlasssx
Feb 5, 2010 06:42 AM
oldsdroptop
Apr 18, 2009 07:06 PM
kaptmikey
Drivetrain/Differentials
Feb 25, 2009 04:45 PM
