Hot 442
Old Jun 6, 2011 | 06:35 AM
m455sx's Avatar
Olds Nut
Hot 442
I was wondering if a turn off valve can be installed on the heater hose to prevent the coolant from going into the heater core? It still has heat coming in to the inside of the vehicle even though the lever is on cold, but not as hot when the lever is on the hot side when i cut the air conditioning on the heat stops. I rather cruise down the road with the windows down. I have a valve installed on my vette with no problems.
Old Jun 6, 2011 | 02:36 PM
64Rocket's Avatar
If you have A/C you already have a hot water valve. The valve may be stuck open. There is vacuum hose from the engine to control panel to operate the heater/A/C flapper doors under the dash. Check your vacuum and all the vacuum pods that operate the heater-A/C doors. Also check if the vacuum hose is connected to the hot water valve, which is on the passenger side rear of the intake manifold.
Also check if the water valve is there!
Gene
Old Jun 7, 2011 | 08:29 AM
m455sx's Avatar
Olds Nut
Thank you for the info. The heater core has a leak so if i cut it to heat it will drip and if i cut it to cold it doesn't. But running down the road you can feel heat coming from the vents, i will reseach the flapper door to make sure it is working properly.
Redog
Mar 18, 2012 09:21 AM
67Olds442X2
Jun 14, 2011 06:20 PM
Aceshigh
May 23, 2010 08:06 PM
dan1s
Apr 17, 2010 08:14 AM
Oldsproject
Jun 21, 2008 07:03 AM
