Hooker Headers warranty
Old October 17th, 2014 | 03:18 PM
DLaz70OLDS98's Avatar
I purchased a set of ceramic coated Hooker Headers and they arrived today. I read through the paperwork and right there at the top was a statement. Basically it indicated ceramic coated headers can't be used on engines that are being broken - in as it will ruin the coating. Perhaps this is common knowledge just not to me. So my question is, has anyone ever broken in an engine with the headers and if so what we're the effects? Should I get a cheap pair of flow techs to brake the motor in?
Thank you for any feedback.
Drew
Old October 17th, 2014 | 08:41 PM
70cutty's Avatar
Beer Connoisseur
Put them on, brake it in and don't worry about it.
I used my hookers when I was breaking in my 350, nothing happened.
Old October 17th, 2014 | 08:49 PM
steve442's Avatar
Agreed..
Old October 17th, 2014 | 08:59 PM
What was on the engine before?
Old October 18th, 2014 | 02:40 AM
rustyroger's Avatar
'87 Delta 88 Royale
Why would breaking in an engine affect the headers?.
Maybe if it has a lean running cylinder that gets excessively hot there could be an issue, but an engine with 30k miles behind it could develop a fault giving similar symptoms.
Roger.
Old October 18th, 2014 | 03:30 AM
Eric this is a new motor that has not been fired up yet.
Old October 18th, 2014 | 03:34 AM
Roger.
Roger the issue seems to be with the ceramic coating. Apparently there is a process to properly breaking in the ceramic coating. I think I'm going to install the new hooker and call it a day.
Thanks for the input guys.
Drew
Old October 18th, 2014 | 03:49 AM
rustyroger's Avatar
'87 Delta 88 Royale
Originally Posted by DLaz70OLDS98
Roger the issue seems to be with the ceramic coating. Apparently there is a process to properly breaking in the ceramic coating. Drew
Thanks Drew. What is the correct procedure for doing this?. I'm just curious, I don't forsee me putting them on my car in the near future.
Roger.
Old October 18th, 2014 | 04:27 AM
Roger.
Roger, the paper work just indicates that the ceramic coated headers require several heat cycles to fully cure before they will withstand extreme heat. I Googled this issue and there was a mix of comments. Some saying just install them and others saying to use a cheap set or a set of manifolds.
I guess it's not a huge deal, it's not like they are a set of ARH!
Old October 18th, 2014 | 05:35 AM
All coated headers have this warning. I think it's because during initial break in you may have timing issues and/or a lean condition causing excess heat and there by damaging the coating and causing finish issues.
Old October 20th, 2014 | 07:32 PM
This is it. A while back I talked to Jet Hot Coatings and was told that the ceramic could discolor during engine break-in. Not a big deal to me as I was looking for a dark (black) coating so discoloration wouldn't apply.
BeenThere
February 8th, 2013 02:07 PM
Lady72nRob71
November 2nd, 2011 10:56 AM
FTW65W29
December 18th, 2010 07:47 PM
JSGD1966
August 27th, 2008 07:46 PM
spikey0922
January 11th, 2003 11:31 PM
Quick Reply: Hooker Headers warranty
