Hood Locks
Old Aug 15, 2014 | 08:50 AM
webby's Avatar
Hood Locks
Need info on removing the chrome hood locks on OAI hood. I've got one that's broke and can't open hood. Any thoughts would be appreciated.
Steve
Old Aug 15, 2014 | 09:50 AM
RetroRanger's Avatar
72 Olds CS
On mine one of the hood lock roll pins slid part way out of the chrome part and wouldn't allow you to rotate the lock to release the hood, if that's whats up w your you can Barely access the pass side from underneath I was able to coax the pin the rest of the way out w long 12" needle nose pliers ...idk if you could get to the drvrs side
Old Aug 15, 2014 | 10:15 AM
stevengerard's Avatar
you can not access the drivers side because of the battery. This happened to me and a buddy's car. What I did is just wiggle the hood lock over and over again until the pin shifted in place. Happened a few times, one time I got it out quickly the other time I had to go back to it a bunch of times as it took a long time.
Old Aug 15, 2014 | 11:50 AM
Yup, this is a common problem. On my 70, I had to carefully lift up on the hood and pry under the lock area until the pin bent and I was able to get the hood open. Spring pins are available at most hardware stores.
Old Aug 15, 2014 | 12:40 PM
webby's Avatar
Hood locks
I am able to rotate the the hood latch, it must not be lining up properly to release. By the way it is passenger side.
Old Aug 15, 2014 | 12:54 PM
Again, the problem is that the pin in the shaft of the **** slides to one side. The result is that it sticks out too far on one side and won't clear the slot in the bracket on the core support. You can still turn it, but you can't get the hood open because the pin hangs up in the bracket. Please see the posts above.
Old Aug 15, 2014 | 01:38 PM
that is why I slide the hood pin back and forth while occasionally pulling up - the friction will eventually slide the little pin enough that it is in the correct place - its trial by error or do what Joe aid - I had to do that once on someones car as well.
I wonder if that is why so many of these hoods are cracked - one gets frustrated and WHAM!!!! - 35 years ago it was just a used hood to many.
Old Aug 16, 2014 | 12:19 PM
webby's Avatar
Thanks for the ideas.
Old Sep 1, 2022 | 07:15 AM
mfarrell's Avatar
I've experienced the hood lock pin issue as described by many. Can anyone tell me where they have found replacement pins without purchasing a whole lock kit? thanks.
Old Sep 1, 2022 | 07:21 AM
They are spring pins. Tractor Supply, Fastenal, McMaster Carr, etc, etc.
Old Sep 1, 2022 | 07:25 AM
4+4+2=10's Avatar
Any good hardware store will have them, but if you strike out there are multitudes to choose from on line..
roll pins roll pins
Old Sep 1, 2022 | 09:48 AM
442Dude's Avatar
I had this happen once on each side to my pins and it was a bugger to get the hood open. Once I did....I tried a different solution. I straightened the pins out perfectly and then added red Loctite to the knurled section of the pin center. Once I squeezed that into place and let it dry...the pins don't move but they could easily be forced out later if desired. Spring pins are a great idea as well.
Good luck!
Old Sep 1, 2022 | 01:58 PM
Del70's Avatar
Never had a pin shift after installing set scews....
Del70
Jul 13, 2022 03:46 PM
69ishHoliday
Body work
Nov 19, 2013 06:05 AM
theoldsrocket
Mar 24, 2011 01:03 PM
brandon reynolds
Mar 16, 2010 07:02 PM
StickW31
Feb 25, 2010 01:14 PM
