Hit a roadblock with carb re-assembly
Old Oct 9, 2009 | 01:33 PM
nukesec1's Avatar
This may seem simple, but I wanna get it right the first time. Rochester Quadrajet 4bbl. The float needle pull clip "hangs" off the float, correct? The spring clip keeps falling into the "slots" on the back of the float.
Old Oct 9, 2009 | 01:46 PM
nukesec1's Avatar
I think I got it. The pull clip hook from underneath the float.
Old Oct 9, 2009 | 07:49 PM
MX442's Avatar
My rebuild book says that the clip is not needed, so I left it out. Hopefully I won't have any problems.
Old Oct 10, 2009 | 08:39 AM
Run to Rund's Avatar
I hook the clip on one side arm going from the float to the pad where the needle hits. the clip is a "fail safe" in case the needle sticks in the seat.
Old Oct 10, 2009 | 08:41 AM
wmachine's Avatar
Trying to remember member
X2
Old Oct 10, 2009 | 08:46 AM
oops, the above doesn't work on all carbs. On a Qjet, hook the clip on the cross pad near where the needle hits it. On other carbs, work the float and see that the clip is positioned where it doesn't interfere but will pull the needle when the float gets near its farthest travel (nearest the bottom of the fuel bowl.) The clip also helps pull the needle off the seat when fuel pressure/level is very low.
jeffsims
Feb 26, 2013 05:16 PM
jensenracing77
Silhouette
Jul 10, 2009 08:15 PM
easytobedead
Nov 22, 2008 05:46 AM
