Help Pulling Motor and Trans
So I am close to pulling the motor and trans in my 69 442 but, one thing is stumping me. I have disconnected all linkage, lines, etc, to the trans and all engine-related items. The trans tail shaft is the question. I was anticipating two bolts to release the front yoke from the U-joint but that doesn't appear to be possible. Does the trans tail shaft have splines that slide out of the trans body? I am stumped so anyone with experience with pulling motor / trans please chime in.
Sean
Sean
I'm not entirely clear on what you mean, but to remove the driveshaft, you remove the four screws that hold the two yokes that retain the bearing cups of the rear universal on the input shaft of the differential, then you unseat the universal from its cradle, then you pull the driveshaft rearward to pull the slipyoke out of the back of the transmission.
Be sure to have a tub under the back of the transmission when you do this, as plenty of oil will make its exit. Leave the tub there as you work, as more oil will come out every time you move the car, and if you pull the transmission attached to the engine, when it tips up, all the rest of the oil will come out.
My only addition is that you can get plugs for the tailshaft of the transmission to keep fluid from pouring out every time you move it. A friendly transmission shop may even let you borrow one or tell you where to buy one.
Good luck.
Steve
If they work, I'll throw one in the toolchest for next time, myself!
They fit pretty snug but if you are worried about knocking it out you could always plug it and then put some duck tape around it to the tailshaft to be sure. There isn't a lot of pressure there since a lot of the fluid is lower than the tailshaft in the pan but I suppose it can be under a little pressure if the trans is closer to vertical coming out of the car with the engine.
-Steve
-Steve
Guys, thanks for the input. This is exactly what I did and everything went smoothly. The exception being I was not prepared for the rapid dump of fluid. I do think the plug on the tail shaft would be useful when reinstalling to help limit the mess.
Thanks again
Sean
Thanks again
Sean
What he said is correct, unbolt from the differential and then slide the yoke with driveshaft out of the trans.
Good luck.
Steve
Good luck.
Steve
You can also just slip a rubber glove over the tail shaft and secure it with a rubber band to keep any fluid from draining on to your garage floor.
At least the seals are cheap.
![Big Grin](https://classicoldsmobile.com/forums/images/smilies/biggrin.gif)
Most people I know seem to just use the front splined section of a drive shaft to plug the hole. I don't bother. I always drain them into a tub and do a new rear seal. Good opportunity for a fluid change, although ATF is getting a bit more expensive lately. ![Smile](https://classicoldsmobile.com/forums/images/smilies/smile.gif)
At least the seals are cheap.![Big Grin](https://classicoldsmobile.com/forums/images/smilies/biggrin.gif)
Cars are still here. Wife long gone.
![Wink](https://classicoldsmobile.com/forums/images/smilies/wink.gif)
cjmazzeo
January 25th, 2015 04:50 AM
ChefDeadpool
37
May 23rd, 2012 08:32 PM
Aceshigh
September 29th, 2010 10:31 PM
