Help Identifying Distributor, Waterpump and Carburetor Part Numbers
Old February 2nd, 2020 | 12:58 PM
twilightblue28A's Avatar
I will appreciate member's help identifying the following components and part numbers please:
Distributor #1111042
Waterpump # 398021F or might be # 393021F
Carburetor # 7040256X (Service replacement?)
The part numbers are taken from a 1970 442.
Thanks as always!!!
Old February 2nd, 2020 | 01:27 PM
2blu442's Avatar
My reference shows the distributor as correct for 1965,66,67 400 engines depending on the date code stamped after the application numbers. It would be a combination of numbers and a letter. The water pump number you posted looks like the block casting number on the shelf above the water pump. Check the thread for a water pump for sale by kennybill, that will show you the correct location for the water pump number. The carb number is a very rare number, but being a factory replacement carb would drop that significantly but still a rare number. That number is for a 1970 442 W30 with a manual transmission. Let us know if you have any more questions. If there's any doubts, please post photos of the numbers/locations your looking at on your engine.
Old February 2nd, 2020 | 01:55 PM
Photograph of the waterpump. Thanks!!
Old February 2nd, 2020 | 02:06 PM
2blu442's Avatar
Yes that's the block casting number. Check this thread, it has a good picture showing the water pump numbers where the big hose that connects with the bottom radiator hose attaches to the water pump. https://classicoldsmobile.com/forums...4847-a-142161/
montvaleplace
April 5th, 2019 11:17 AM
vickycar
August 12th, 2017 08:20 AM
The Stickman
October 10th, 2015 06:17 PM
PrairieOlds
May 27th, 2013 07:08 PM
4-ever-olds
October 3rd, 2009 09:51 PM
