Help with the hood.
Old Apr 25, 2018 | 04:26 PM
Dadsbadass442's Avatar
Help with the hood.
Slide5.JPGSlide3.JPGOlds Gods. Looking for some help / advice here. I'll describe here my issue and hopefully the annotated pics help. Drives side, rear of the hood sits high. I can push it down and it's level until I drive the car or raise the hood. You can see from the pics the hood is all around squared on the car as it should be. The hinge on the drives side needs to be adjusted I'm guessing and no clue where to start or trouble shoot the hinge to make it stay flush. Any help out there. Thanks much! By the way, got this off the Dyno this week and jetted for 7000 ft here in Colorado. Holy cow this is fun to drive.
Old Apr 25, 2018 | 05:10 PM
stan 65 cutlass's Avatar
you need to put spacers between the hood and hinge, so it pushes down further, nice louvers by the way
Old Apr 25, 2018 | 06:23 PM
Stan 65 Cutless. Here is the hinge on the high side. Wouldn't I take spacers out to bring it level?
Old Apr 25, 2018 | 06:29 PM
no, put the spacers between the hinge and hood, it helps to lower the hinge to where it is pulling, there was a discussion i remember about the trunk, it was the same theory
Old Apr 26, 2018 | 04:20 PM
And for all that is good and holy, do NOT think that washers = spacers. That hinge has a fitted fit because it provides stiffening over the whole cross section. If you put a washer there, lifting the hood and letting the hinges stop it will eventually bend the mounting holes as only the washers are stiffening that area. You need shims, which are pieces of sheet metal the size of what you are spacing, with a hole in the right place. You could get away with two shims there, one on each area (there's two different heights.). I would think the width of the hinge and about 2x that long would be good.
Old Apr 26, 2018 | 06:05 PM
ive seen quarter inch spacers on the trunk lids, bear in mind the hinge will go lower than the hood will allow,creating more pull
jonesolds442
Jul 11, 2019 02:28 AM
Hurst/Olds 73/74
Sep 24, 2016 09:31 PM
nolabigdawg
Nov 16, 2014 06:45 PM
georgiaboy697
Jul 2, 2010 09:23 PM
MJAKS462
Apr 15, 2010 02:34 PM
