help with 73 delta 88 engine install
so, im in the middle of an engine swap in my 73 delta 88 and can use some info on a couple things....
the original engine that was in there was a olds 455, my dad 20+ years back swapped in a buick 455.
now whats going in there is an olds 425.
i know that on the side of the block are 3 holes, on each side, where 2 of them
are for the engine mount.
my guess is that the engine mount attaches to the rear 2 holes, and the front hole (on the drivers side) is for the power steering bracket.
my question is...(for all the delta owners -since i have yet to install a 455 inmy 71 cutlass).....
are the rear 2 holes the correct holes to mount the engine mounts to ?
i currently have the engine attached to the trans, and the engine mounts on the 2 rear holes in the block, but since i DO NOT have the frame mounts, not sure if thats 100% correct.
the buick blocks frame mounts sat closer to the front of the frame, seems to me that the original olds frame mounts sit closer to the rear of the frame.
am i correct in placing the engine mounts in the rear 2 holes ?
BTW:
if any 455 delta 88 owners can be so kind to take a pic of their engine mounts while on the car...so i can see where they mount up to...and possibly see the frame mounts...id really would appreciate it
the buick motor went to a buddy that help me with the install...he is building it for another buddy's buick electra
![Cool](https://classicoldsmobile.com/forums/images/smilies/cool.gif)
Sorry, that is not correct. The front two holes are only used on the 1964-1970 full size cars and the 1973-74 Omegas. The OP's 73 D88 uses the REAR two holes, same as every 1971-1990 full size RWD Olds. FYI, on those cars that do use the front two holes, the PS pump bracket spacer is thinner than on the other cars.
this is why i would like to see some pics....2 different answers...
so...again....if anyone with a 1973 delta 88 with a 455
can snap a pic or 2....of the mounts (both frame and engine)
id greatly appreciate it....
if i can return a favor of the same caliber...let me know. id easily take a pic to post if i have access to the information requested
thanks
thanks for the info....
thanks
thanks
![Thumbs up](https://classicoldsmobile.com/forums/images/icons/icon14.gif)
including the pics of the mount locations. you are correct with the info on
the rear 2 holes on the block.
appreciate it
2blu442
November 10th, 2012 10:16 AM
84oldsDelta88
June 1st, 2010 05:51 AM
