Help with 1957 Olds Super 88 Front Shock Install
Old December 25th, 2021, 07:45 AM
cjmazzeo's Avatar
Hi to all,
I have a 1957 Olds Super 88 that I am doing a body on frame restoration. Right now the engine and transmission are out of the vehicle. Other than replacing tie rod ends, we did not rebuild the front suspension as it was tight and in good condition.
I went to install the front shock absorbers and I am trouble getting them to fit. The new shocks are the same height as the old ones when fully extended. When I go to install them, the top of the shock, where the bushing and hole opening are, are about 1/2 below the hole on the shock tower. There are no brakes or drums on the front spindles as they are yet to be replaced. The vehicle is on a lift and supported under the frame.
I have tried several ways to move the lower control arm up, but with no success. This has included lowering the vehicle so that the rear of the vehicle is on it's wheels and placing the front spindles on jack stands. This did not work. All this did was raise the car off of the lift at the front. Any ideas or suggestion or telling me what I am doing wrong would be much appreciated.
Thank you.
cjmazzeo is offline
Old December 25th, 2021, 09:05 AM
Wait until there is more weight added to the vehicle so you can raise the lower control arm.
oldcutlass is online now
Old December 25th, 2021, 09:18 AM
RandyS's Avatar
You could use a spring compressor to shorten the coils, then use some very stout wire (I used wire coat hanger) to wire the coils in the conpressed state. Remove the compressor and iInstall the shocks, then realease the wire - carefully..........
RandyS is offline
Old December 25th, 2021, 09:31 AM
Just wait until the drivetrain is back in the frame. Anything else will be half-fast and potentially dangerous.
joe_padavano is offline
Old December 25th, 2021, 10:45 AM
Proud Viet Nam Veteran
redoldsman's Avatar
I have a hard time believing coat hanger wire would hold the springs. Do what Joe said. You are not going to drive it until the engine is in anyway.
redoldsman is online now
Old December 25th, 2021, 12:04 PM
Sugar Bear's Avatar
Agree waiting is best. If you get them installed and then release the spring tension or remove the weight the shock will be keeping everything compressed under tension and the shock may break or worse yet unleash unexpectedly. Wait...
Sugar Bear is offline
Old December 25th, 2021, 12:37 PM
fleming442's Avatar
Error in procedure. Never do suspension work without the full weight of the car. You'll fight yourself for no reason.
fleming442 is offline
Old December 26th, 2021, 07:50 AM
cjmazzeo's Avatar
Hi to all,
Thanks to all for your feedback. I will wait to install the shocks until after the engine and trans are it.
Joe
cjmazzeo is offline
Zabkarian
March 3rd, 2020 07:52 PM
stokerg
Suspension & Handling
February 23rd, 2017 06:37 AM
Zabkarian
October 1st, 2014 08:04 AM
Zabkarian
September 29th, 2014 02:56 PM
Jaws1982
August 8th, 2014 03:12 PM
Quick Reply: Help with 1957 Olds Super 88 Front Shock Install
