Help
Old Mar 19, 2018 | 10:56 AM
richkidd24's Avatar
Help
So i have 1969 f85 and I'm guessing someone changed the steering column from column shift to floor shift and now I'm having problem with neutral safety switch how would I go about moving it from the column to floor shift
Old Mar 19, 2018 | 11:01 AM
2blu442's Avatar
Do you have a factory floor shifter? If so you'll need to get the correct neutral safety switch, then get a pigtail or extend the wires from your column to the floor shifter. John
Old Mar 19, 2018 | 02:53 PM
rocketraider's Avatar
Oldsdruid
Doesn't 69 have backdrive linkage that operates the steering wheel lock and NS/backup lamp switches? Or did that come later on the locking columns?
That's the trouble when you get hold of something someone else has cobbled up and didn't document how anything was done, what the new parts came from, ad nauseam...
Richkidd, you have a perfect example of POS! Previous Owner's Stamp!
Old Mar 19, 2018 | 03:31 PM
Whoever installed the steering column either didn't reinstall the backdrive linkage or did not adjust it properly. Either is an easy fix.
Old Mar 19, 2018 | 05:01 PM
richkidd24's Avatar
how would i go about reinstalling the back drive linkage or adjusting it
Old Mar 20, 2018 | 05:32 AM
Rustbucket2's Avatar
Is this what is being discussed? Yes my linkage rod over header is bent, welded header pipe a little high, had to bent to make it work.
Old Mar 22, 2018 | 06:50 PM
richkidd24's Avatar
yeah i don't have any of that on mine
nolabigdawg
Nov 16, 2014 06:45 PM
MJAKS462
Apr 15, 2010 02:34 PM
silverriff
Mar 24, 2010 06:36 PM
martine
Jan 22, 2009 01:13 PM
ToronadoGuyDenver
Brakes/Hydraulic Systems
Mar 18, 2007 02:52 AM
