Heater Core Removal
Old August 3rd, 2013, 05:06 PM
nelsontj's Avatar
Heater Core Removal
I removed 5 nuts and 2 bolts from the outside (engine bay) heater cover, but I can't get the interior heater box to come out. It is on a 1970 442. Any suggestions or ideas?
nelsontj is offline
Old August 3rd, 2013, 05:08 PM
Octania's Avatar
Pull harder?
Look for places it is not moving, might be a hidden fastener there.
Octania is offline
Old August 3rd, 2013, 05:11 PM
nelsontj's Avatar
Forgot to mention it is a non A/C car. I looked at the reproduction outside heater box replacement and it looks like seven fastners is what it takes so I think I have all the fastners off.
nelsontj is offline
Old August 3rd, 2013, 05:15 PM
There is one nut way under the fender in an area where small hands are required. Use a light and a mirror and you can see it. By the way this is the only time that you will be happy not having A/C.
Then get in the car and remove the heater box from under the dash.
oldcutlass is offline
Old August 3rd, 2013, 06:22 PM
nelsontj's Avatar
I loosened all the bolts to the inner fender so I could get to one of the bolts, if that is the one you are talking about. There is one bolt on top behind the fender that I wonder how I am going to get it started back in without removing the hood and fender. It is as tight as can be. Does anyone out there know if there are more than 5 nuts and 2 bolts to that application?
nelsontj is offline
Old August 3rd, 2013, 06:26 PM
66luvr's Avatar
I have found nuts between the inside and outside heater boxes. It's as if they put nuts on to hold the inside box in place until the outside box was put in place, and just left the nuts there. The seam sealer made it all waterproof.
Good Luck,
Mike
66luvr is online now
Old August 3rd, 2013, 06:45 PM
Well then it's probably just stuck, keep working at it.
Old August 5th, 2013, 06:22 PM
nelsontj's Avatar
I did get the interior heater box out and got at the leaky heater core. I ordered a new brass/copper heater core. They are a bit pricey and may be overkill as I haven't heard of a lot of heater core replacements with the cheaper aluminum units. I don't use the heater very much in this car. I ordered new carpet and firewall pad because I don't want to deal with mildew, mold or odors later on from the soaking those two items took.
nelsontj is offline
JackJack56Olds
March 16th, 2015 07:51 AM
bigretic
October 3rd, 2014 03:05 PM
4Ceesuns
May 28th, 2014 12:32 PM
1968Cutlassfallbrook
October 30th, 2009 09:05 PM
kevinkpk
June 8th, 2008 02:25 PM
Quick Reply: Heater Core Removal
