heads and other questions
Hi ya'll doing sorry been awhile since I posted on here, well I just read the book "How TO Build Max-Performance Oldsmobile V-8 by Bill Trovato" and he said the 7A heads are from a 307 engine. But everything I've read on the interweb says 7A are 350 heads with a 64cc chamber. Now just to clarify I want to get 350 hp to 400 hp on a very tight budget. That's why ordered this book but all it did was confuse me more so any help or if someone can give a course of action or which way to go to achieve the desired results would be great as in what cam should I get or should I go with a hei setup or stay stock on ignition things like that would be great. And thanks again for the all the input.
The 7A you're looking for has the "A" as a subscript down to the right of the "7". They were on 1972 350's. The 7A's from the 307's have the same size "A" as the number 7. The "A" denotes hardened valve seats in Oldsmobile heads. I don't know of anyone who has sunk a seat like Chevys do... If you're looking for higher compression on a smog engine, try 330 heads, #3, #4. They have smaller combustion chambers than the 350 heads.
" Note that the 1972 heads are 7A, whereas the 1980s heads are 7A. The casting numbers above the center exhaust ports are also different. The 1971-72 heads are casting number 409147. The 307 heads are 0142"
in the earlier days of the internet, we had text. ASCII characters, period. In order to distinguish the two significantly different types of cylinder head with similar main casting ID, I adopted the practice of writing "7a" for the 1972 version with the small [and subscript] upper case "A" - leaving "7A" to represent pretty much exactly as shown on the head the later smog era roller cam 307 head ID.
Now that we can make tiny upper case [and nearly subscripted] "A" characters like seen above, we should just do that. When in doubt, include the casting number as well. With the main ID and the casting number, the part should be pegged.
The 7a/7A head confusion is but one example.
There are L & R "W" exhaust manifolds
Two different "H" exhaust manifolds?
two distinctly different "KB" crank pulleys
two different "J" intakes....
plus factory casting ID typos which I have documented. See the INTAKES thread here for an example.
Newsmobile69
Ninety-Eight
60
August 18th, 2016 02:42 PM
jensenracing77
Paint
September 10th, 2014 02:33 PM
69oldsdelta88
Brakes/Hydraulic Systems
May 8th, 2009 02:33 PM
