Has anyone installed hooker 3902 on cutlass with 350?
Old Dec 29, 2013 | 05:21 PM
Big Leche's Avatar
I found some 3902 here in town that are affordable. Not sure if I should use them on my 771 cutlass with 350 or not. I was hoping to get them in the 50-75 range in order to keep my exhaust affordable. Are there any issues installing these on a car with small block?
thanks in advance.
Lech
Old Dec 29, 2013 | 06:41 PM
w-30dreamin's Avatar
71 & 72,now I want a 68
According to both Jegs and Summit,the 3902 header is for 400-425-455 engines.
Old Dec 29, 2013 | 07:06 PM
The difference in deck height may cause interference with oil filter, starter, and structure.
Old Dec 29, 2013 | 07:19 PM
69ishHoliday's Avatar
Hooker 3901-1HKR should fit your application.
I just had a set installed into my 69 Cutlass and it reportedly required very little adjusting. I did also change the motor mounts to new because I had read where shot motor mounts contributed to difficulty getting headers to clearance.
Old Dec 29, 2013 | 08:46 PM
Big Leche's Avatar
Headers
Unfortunately the headers that are available are 3902 with ceramic coating. Only reason I was asking is because I can get them cheap. I looked up what they fit and saw the 400 403 455 but figured that 350 and 455 use same headers some what. I know that the ones im looking at for my cutlass right now on ebay list that they fit both 350 and 455 applications so I was wondering if the hookers were the same.
thanks
Aceshigh
Jun 21, 2016 05:28 AM
Johnd
Body work
May 8, 2014 09:54 AM
Napoleon1991
Jan 10, 2014 03:25 PM
815Cutlass1972
Feb 20, 2011 12:45 PM
